Budget vs premium swivel seal (BigJimny shop)
- GandHisJimny
Topic Author
- Premium Member
- Thank you received: 14
16 May 2024 14:28 #255971
by GandHisJimny
Jimmer II (2007 JLX+ auto in black & silver) : Android head unit, Black Raptor Steering Damper, Yokohama Geolandar G015s, rear cabin light, OEM wind deflectors
Budget vs premium swivel seal (BigJimny shop) was created by GandHisJimny
Hi all, looking to do my kingpin bearings and I see there are two options in the shop for the swivel seals - a budget and a premium OEM option.
Budget: www.bigjimny.com/store/kingpin-bearings-...seal-kit-budget-seal
Premium: www.bigjimny.com/store/kingpin-bearing-w...it-premium-koyo.html
Is it worth the extra ~£20 a side for the OEM Suzuki ones or should I just go budget? From what I understand these seals aren't super important and are mostly just to stop dust and a little bit of water ingress. I may be mistaken on that though.
Thanks!
Thanks!
16 May 2024 17:26 #255973
Replied by yakuza on topic Budget vs premium swivel seal (BigJimny shop)
Water ingress is what kills the bearings.
So I would choose the better seal.
But again could be just a fortnight in life span difference too...
The following user(s) said Thank You: GandHisJimny
- Thank you received: 664
16 May 2024 17:39 #255975
Replied by DrRobin on topic Budget vs premium swivel seal (BigJimny shop)
Kingpin bearings on a Jimny seem to fail very quickly and given the length of job personally I would (and did) fit the best.
Martin would be the person to know if there is any real difference.
Along with a new seal I would order replacement bolts for the seals, they aren’t expensive and mine were covered in crud and rusting.
Also if your car has ABS the bolt holding the sensor in snaps really easily, both mine did. However, it’s very easy to drill out and replace, I found some stainless steel ones for mine.
Robin
Robin
- GandHisJimny
Topic Author
- Premium Member
16 May 2024 17:41 - 16 May 2024 17:45 #255976
by GandHisJimny
Replied by GandHisJimny on topic Budget vs premium swivel seal (BigJimny shop)
Yeah, I've been doing some Googling and it seems like some schools of thought are "well, water is getting in no matter what you do so just accept it" whereas other people talk of sanding, filling & painting their swivel housing in an attempt to make the surface smooth.
My mind is telling me to get the OEM ones but the Scotsman inside me wants to be cheap
And yes @DrRobin - I'm going to replace every bolt I remove and have accepted that drilling out the ABS one is pretty much just part of the process. I read that if you buy an extra swivel seal bolt then that fits as a replacement! Not 100% on that though.
Last edit: 16 May 2024 17:45 by GandHisJimny.
16 May 2024 18:27 - 16 May 2024 19:33 #255977
Replied by mlines on topic Re:Budget vs premium swivel seal (BigJimny shop)
Hi, thanks for your question
The premium seal is a genuine Suzuki seal and the budget seal is an aftermarket one.
As everyone says, it's more of a dirt and dust cover than a seal and a really can't say which is longer wearing, that's because I have only ever fitted genuine to mine
I have added pictures. Depending on your device and the way it displays pictures the genuine ones are on the right or on the bottom.
The main ring on the Suzuki version is a different design, it is split. It has a felt lip and cutouts in the inner lip to aid steering. The budget is a plain metal pressing. The rubber section on the genuine is quality rubber which is pre greased in the correct position. The budget is a plain ring with some sort of glittery finish.
The inner ring is a simple pressing although the Suzuki one is more rigid which suggests its better quality metal.
I would suggest the budget is for an off roader and the premium is for a road vehicle
Sent from my ThinkPhone by motorola using Tapatalk
Last edit: 16 May 2024 19:33 by mlines.
The following user(s) said Thank You: gv42, GandHisJimny
16 May 2024 19:03 #255978
I think that the ABS bolt will be slightly longer than a seal bolt, but again ask Martin, he will know. They drill out very easily, one of mine just came out with a fairly small drill bit and the thread was fine, just gave it a good clean. The other was stuck good and solid and had to go up in half drill bit sizes until it disintegrated and came out. The threads on that side were caked, so I ran a tap through first with some cutting fluid to clean the hole out. If you haven’t got a tap or cutting fluid you can do the same with a small piece of rag and some oil or thread release. Then run a bolt through several times to push the muck out. I put mine back in with copper slip/grease.
Robin
No one likes paying more if they don’t have to, or is that because I am a Yorkshireman, often described as a Scotsman without the generosity. I thought Martin’s write up was very comprehensive, thanks Martin, perhaps you should pin your description to the shop/wiki?My mind is telling me to get the OEM ones but the Scotsman inside me wants to be cheap
Robin
Time to create page: 0.162 seconds
