Alternator belt/water pump question
20 Aug 2022 10:51 #244647
by Abudougal
Alternator belt/water pump question was created by Abudougal
Had a pretty exiting night, the belt had been squealing for a bit and suddenly popped with ten miles to get home and no alternator or water pump.
Managed to nuirse it back without too much overheating and I've got a new belt to put on, it looks pretty tight in there - any handy tips to save the skin on my knuckles a bit?
- Thank you received: 667
20 Aug 2022 16:35 #244652
Replied by DrRobin on topic Alternator belt/water pump question
My Jimny spat both belts off almost outside the house, one had been squealing, so I assumed it wasn’t set correctly, I re-fitted both, but didn’t get very far, it turns out that the crankshaft pulley rubber had gone, looks like a weak point on these cars.
It damaged one belt so ordered a new pulley, which arrived with a small bit of damage and two new belts. I had to fit the damaged pulley for a week, then do the job again with the replacement, you get good at it.
To do the pulley you need to take the radiator off, but this is quick and easy, the belts can be done from above and below with the radiator in place, but without the radiator are easier to do.
I would check your pulley to make sure it is okay.
Robin
Robin
20 Aug 2022 17:59 #244655
by Abudougal
Replied by Abudougal on topic Alternator belt/water pump question
Thanks I'll check that too, presumably just a case of eyeballing it and seeing if it's a bit squint?
Is it possible to check the pulley without whipping off the rad?
21 Aug 2022 07:44 #244660
You might be able to see if the pulley has gone by looking from below, or you might be able to feel Play in it, but f you put the belts on and tension them you will definitely see the pulley is out of line.
The rad is very easy to remove, 20 min job.
Here is the post from when I did the job.
www.bigjimny.com/index.php/forum/6-jimny...-belts-just-fell-off
Robin
Robin
21 Aug 2022 15:42 #244673
by Busta
Replied by Busta on topic Alternator belt/water pump question
You can gain a small amount of extra space by removing the 2 top radiator bolts and tilting the radiator towards the front of the car. But it is easy enough to do with the rad in place. For reference, the alternator bottom bolt that you can't see is an 8mm hex. The power steering tensioner has a 10mm hex hole for tensioning it.
21 Aug 2022 17:15 #244674
Replied by mlines on topic Alternator belt/water pump question
Shine a torch on the lower pulley, in my experience you can clearly see a wobble as its idling
Time to create page: 0.226 seconds
