Towing a trailer with 2019 Jimny
- Roger Fairclough
- Thank you received: 211
29 Apr 2021 08:25 #234755
by Roger Fairclough
Replied by Roger Fairclough on topic Towing a trailer with 2019 Jimny
In the UK the maximum towing weights for the Gen.4 are 1,300 kg for a braked trailer/caravan and 350kg un-braked. .These limits apply to manual or auto g/box Organisations such as the Caravan Club suggest lower limits ie a max of 80% of the tow vehicles weight as they take into account practical experience.
Roger
Roger
The topic has been locked.
- Thank you received: 556
29 Apr 2021 13:19 #234756
Replied by DrRobin on topic Towing a trailer with 2019 Jimny
I think you might find that your insurance will be invalid if you go over the maximum tow weight for the vehicle, certainly if you have an accident and they decide the trailer is at fault.
29 Apr 2021 14:32 #234757
by 300bhpton
That 80% rule from the caravan club seems to be a figure plucked either out of thin air, or from their backsides. I'd suggest at best it is 5 decades out of date or more likely, just bad advice that should be ignored completely.
Logically and rationally if you should only tow 80% of the rating, then every vehicle would be rated 20% lower. But they aren't.
As for the op. Really depends very much on the laws in the country you are in. And how risk adverse you are. 450kg is not really significantly heavier than 350kg. I'd be amazed if 100kg would make any real difference under normal road and driving conditions.
The only thing I'd really suggest above and beyond what has already been mentioned, is to check the actual weights. 450kg seems fairly light for 2 x motorbikes and the trailer. If in the UK you will need to know the MAM of the trailer too.
Replied by 300bhpton on topic Towing a trailer with 2019 Jimny
Roger
- Roger Fairclough
29 Apr 2021 15:27 #234758
by Roger Fairclough
From the Defender 90 upwards, all Land Rovers have been rated to tow 3.5 tons.
My KZJ 70 Land-Cruiser was rated to tow 2 tons. Does this mean that Toyota were more conservative than Land-Rover? In a word, Yes.
The Caravan Club specified 80% of the towing vehicles weight, not 80% of the vehicle manufacturers stated towing limit. There is a big difference and the CCs limit takes into account actual towing. Some years ago I tried to find out if there was a government test to evaluate limits. There isn't one, so the limits are set by the manufacturer to their own formulae.
Doc Robin is correct, as the police would prosecute if you had an accident towing anything that was over the limit and your insurance company would jump at the chance of declining to pay out and that would mean your costs and the other persons.
Looked at mathematically, 450kg is "only 100kg" more than 350kg but if you want to risk it in the light of information typed in this string, then don't come back to us if it all goes pear shaped.
- Thank you received: 1869
29 Apr 2021 15:44 #234759
Replied by Lambert on topic Towing a trailer with 2019 Jimny
Are the caravan club still insisting on the (insert massive swear here) ridiculous 80% thing? I'd have thought in this day and age of persecution of misinformation in all its forms that would have been stamped on by now?
29 Apr 2021 19:42 #234763
by Foxtrot
Replied by Foxtrot on topic Towing a trailer with 2019 Jimny
I have a small caravan which weighs 900kg and it is calculated as 79% of the GEN4 kerb weight with the caravan clubsite outfit match website. They recommend not to tow a caravan more than 85% of a cars kerb weight
Time to create page: 1.750 seconds
