Towing a trailer with 2019 Jimny
  • gajaviki
28 Apr 2021 16:34 #234746 by gajaviki
Towing a trailer with 2019 Jimny was created by gajaviki
Hello!
I just got my first Jimny. Love it so much!
I want to tow a trailer with two motorcycles on it, so overall weight will be around 450kg. While official unbraked towing figure is 350kg, will there be a problem if I tow 450kg? What I should look for?
Thank you!
The topic has been locked.
28 Apr 2021 16:49 #234748 by Roger Fairclough
Towing limits are not just pulled out of a hat. An unbraked load of 350 kg will dramatically upset the balance of your Jimny.
I built an unbraked "A" frame to tow my Gen.2 Jimny behind my Land-Cruiser. I tried a short test run that included a rapid braking test. The Gen.2 nosedived and nearly lifted the back end of the LC off the ground.
I converted the "A" frame to a braked system and everything was fine.
I suggest you do the same.
Roger
The following user(s) said Thank You: gajaviki
  • gajaviki
28 Apr 2021 16:54 #234749 by gajaviki
Replied by gajaviki on topic Towing a trailer with 2019 Jimny
Thank you for your reply.
I will upgrade my trailer with electric brake system.
28 Apr 2021 17:26 #234751 by Lambert
I have a selection of trailers being a farmer, my gen3 tows lovely so long as the weights are observed. Having said that I have on occasion overloaded my unbraked trailer to save time moving stuff across fields and quite honestly don't do it. Being pushed down a hill by an unbraked trailer is quite good at promoting anxiety.
The following user(s) said Thank You: Gadget, gajaviki
  • gajaviki
28 Apr 2021 18:06 #234752 by gajaviki
So, as I understand electric brakes on the trailer and 450kg won't be a problem, right?
28 Apr 2021 18:45 #234753 by mlines
Which country are you in?
In the UK, brakes must have a mechanical means of activating them in an emergency, this is usually a break-away cable so basically means electric systems are not viable.
Time to create page: 0.211 seconds
