Re:gearbox fright
- Tedster
09 Apr 2021 20:13 #234357
by Tedster
gearbox fright was created by Tedster
Hi Everybody.....browsing the forum I saw a couple of comments about the troublesome gearbox ( R72 ) ,
Having just purchased a low mileage 2009 Jimny , which I understand has this box ? what am I looking forward to ?
Is it a catastrophic failure / oil seals / bearings / synchro ? . Why are they considered dodgy and whats the remedy. Gearbox seems fine at the moment .
Info would be appreciated.
09 Apr 2021 20:47 #234359
Replied by mlines on topic Re:gearbox fright
2009, they should have be cured. 2005-2008 are where they had the real issues. However it does no harm to keep the oil topped up and fresh
Sent from my moto g(
power using Tapatalk
The following user(s) said Thank You: Tedster
09 Apr 2021 21:22 - 09 Apr 2021 21:25 #234361
by Scimike
Replied by Scimike on topic Re:gearbox fright
It's fair to say the early R72 had a weak bearing component compared to the early box, but as Martin said the fix was applied 2009 on, it was a sealed rather than an open bearing in troubled location. It's harder to actually confirm how big an issue this was / is.
I also have a 2009 R72 box and it is clocking up plenty of trouble free miles with a heavy caravan attached, and when not it's our only daily transport.I change the oil every 25K because it's cheap to DIY, on all changes the oil I take out has looked like new with no debris, so it's all fine.
So I would not worry, but if your are concerned put £750 in a savings account just in case you need to replair it. Then in 10years when your confidence is high withdraw the £750.03 (includes interest at current rate) and spend it on a party
Oh and congratulations on your new Jimmy and welcome.
Last edit: 09 Apr 2021 21:25 by Scimike.
- Tedster
09 Apr 2021 21:42 #234362
by Tedster
Replied by Tedster on topic Re:gearbox fright
Good thinking......Thanks mlines
- Tedster
09 Apr 2021 21:45 #234363
by Tedster
Thanks Scimike.....but I think the3p interest is optimistic
Time to create page: 0.203 seconds
