Re:VVT Jimny won't start
  • Probablynotfrank
05 Feb 2021 17:45 #232505 by Probablynotfrank
VVT Jimny won't start was created by Probablynotfrank
My Jimny won't start, was happily driving along and it died.
Got no spark, fuel and no engine management light on the dash at all. Checked all fuses, pulled the ecu out and checked the condition of the board, seems fine and no water ingress.
Anyone able to help? Seems like ecu related especially if the immobilizer seems to be functioning correctly? Or have I missed something obvious?
05 Feb 2021 18:40 #232508 by sniper
Replied by sniper on topic VVT Jimny won't start
Check. the big fuse at the side of the positive terminal.....
sniper
  • Probablynotfrank
08 Feb 2021 15:25 #232570 by Probablynotfrank
Replied by Probablynotfrank on topic VVT Jimny won't start
Was one of the first things I checked, sadly not that simple. I've just changed the crank and cam sensor, along with the fuel relay sadly none of it helped.
It has ignition but no engine management light when ignition is on, also turns over and the obd2 won't connect. Is it ECU?
  • Probablynotfrank
08 Feb 2021 17:53 #232571 by Probablynotfrank
Does anyone have the pin out or wiring diagram for the ecu?
08 Feb 2021 21:40 #232573 by mlines
Replied by mlines on topic Re:VVT Jimny won't start
PM me your VIN number
The following user(s) said Thank You: Probablynotfrank
  • Probablynotfrank
09 Feb 2021 19:05 #232607 by Probablynotfrank
Replied by Probablynotfrank on topic Re:VVT Jimny won't start
Think I found the issue, connector into the fuse box next to the battery has a melted terminal in it, further inspection seems the cable has seen better days.... Also need a new connection if Anyone knows where to source?
Time to create page: 0.289 seconds
