Re:Removal of back plate which supports the brake and clutch pedals
08 Sep 2020 17:42 - 08 Sep 2020 17:43 #227932 by HUN
Bosanek wrote: Thank you for the hints.
As I do not have a facility to get the vehicle on a lift at the moment, what do I "lose" if I don't disconnect the clutch cable at the gearbox?
I don't know what you would lose but disconnecting the clutch cable at the gearbox is very easy. All you need is the scissor jack to lift the front right corner of the car then support it with an axle stand for your safety. Undo the plastic nut by hand then take out the bulky cable end from the clutch release folk. (You might need a screw driver as well to carefully remove the plastic cover from the bell housing)
Ha-ha Riccy was faster than me as usual
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
Last edit: 08 Sep 2020 17:43 by HUN.
09 Sep 2020 16:29 - 10 Sep 2020 05:38 #227997 by Bosanek
Thank you very much for these hints. A video says more than a million words.
I managed to disconnect the clutch cable and the brake connection, and managed to undo (with great accessibility difficulty) all 6 nuts which hold the cracked backplate secured to the vehicle body.
So I released the backplate from all 6 bolts, but I can not remove it from the vehicle.
It has go to out in a straight line in order to slide out from the brake connection boot cover. However, the steering shaft blocks that path.
Do I have to remove the steering shaft now and how to do that?
Last edit: 10 Sep 2020 05:38 by Bosanek.
Time to create page: 0.198 seconds
