Re:Removal of back plate which supports the brake and clutch pedals
07 Sep 2020 15:19 - 07 Sep 2020 15:21 #227876
by Bosanek
I have had a squeaky clutch pedal for quite a while, so got fed up with it and decided to investigate.
To my horror, I found out that the thick metal backplate which is bolted to the firewall behind the pedals has a big crack, near the part of the plate through whhich the clutch cable goes. The car is only 7 years old.
Whenever the clutch cable is pulled by the clutch pedal, the cracked part twists and probably squeaks. It will break off soon.
As welding in situ is near impossible due to fire hazards, I need to remove this plate for welding.
If I am correct, I need to disconnect the clutch pedal from the clutch cable and the brake pedal from whatever it is that connects it to the braking system components in the engine bay, and possibly the throttle pedal from the throttle cable.
Lucky me.
Has anyone done this and what kind of advice on all this removal is there? Is it better to have a competent mechanic do the removal and assembly due to risks of messing something up, like the braking system, brake or clutch pedal travel, etc.?
I don't have many local mechanics willing to operate on an "obscure Asian vehicle". Even so, they don't like a sitting vehicle in their garage while the plate is being taken for welding and painting.
Lucky me.
Last edit: 07 Sep 2020 15:21 by Bosanek.
- AdDeTa
07 Sep 2020 15:25 #227877
by AdDeTa
Replied by AdDeTa on topic Removal of back plate which supports the brake and clutch pedals
Good luck and hopefully someone can help, if you don’t have any luck I’ll take a look at mine for you when I’m next working on mine
07 Sep 2020 15:31 #227878
by Bosanek
Replied by Bosanek on topic Removal of back plate which supports the brake and clutch pedals
AdDeTa and me found out two related chapters in the factory service manuals:
5-46 (Brake booster removal and reinstallation)
7C-6 (Clutch cable replacement)
The section on the brake booster says that it should not be disassembled and also mentions some vacuums. The booster appears to be the first component connected to the brake pedal.
Also, suggestions on how to properly dettach and reattach the clutch cable to the pedal?
07 Sep 2020 23:56 #227909
by Keithy
Replied by Keithy on topic Removal of back plate which supports the brake and clutch pedals
When I sold my roof rack to the chap on here who was in the UK from Cyprus his clutch pedal bracket collapsed and I towed him to mine and welded it in situ....made it back to Cyprus across europe ok.....offered to move the steering wheel to the correct side too!
4 nuts and 2 clips to remove.......disconnect the clutch cable at the gearbox first.
08 Sep 2020 14:08 #227923
by Bosanek
Thank you for the hints.
As I do not have a facility to get the vehicle on a lift at the moment, what do I "lose" if I don't disconnect the clutch cable at the gearbox?
08 Sep 2020 17:32 #227931
Replied by Riccy on topic Removal of back plate which supports the brake and clutch pedals
you wont be able to get it off the pedal if you dont release it from the clutch. Its the little plastic triangle cover on the underside. You can crawl under or use ramps and its easy enough when you see it
Time to create page: 1.231 seconds
