springs with dislocating cones
14 Jun 2020 13:23 #223574 by safari
just would like a bit more travel
if u worry u die if u dont worry u still die so why worry
15 Jun 2020 01:47 #223600 by zukebob
The kit you showed would accommodate extra articulation but wouldn't provide it. That was the reason I asked if you had modified your suspension in such a way that you are experiencing spring dislocation. Based on your last comment, I suspect that you aren't having the issue.
With a stock radius arm setup, Riccy's response is 100% correct. You shouldn't experience spring dislocation and, as he and others said, a locker would be your best investment.
15 Jun 2020 08:05 #223601 by maverick
Or get a Kaiser, much better than a Lockrite and cheaper than an ARB
Jalapeño, IISY?
