G13BB 1999 Jimny radiator hose ID
  • Owl
15 Apr 2020 06:20 #221085 by Owl
Hi All, does anyone know what the inner diameter of the top radiator is?
Was thinking of a water temp gauge adaptor fitting? To satisfy my engine temp curiosity, Or unholy worry of overheating the engine.
15 Apr 2020 07:55 #221086 by RainerK
Sorry, I do not know the hose ID.
I would think, that the water temperature at the top Of the radiator is not the hottest spot. Usually a temperature measurement would be at the cylinder head around the 3rd cylinder, supposedly the hottest spot.
  • Owl
15 Apr 2020 08:46 #221087 by Owl
Replied by Owl on topic G13BB 1999 Jimny radiator hose ID
Thanks Rainer, I would have thought monitoring the water temp would give a reasonable general idea of the cooling system efficacy.
16 Apr 2020 08:36 #221124 by Scimike
The temperature of the coolant will give you an idea of how hard the system is working as you wanted, but as RainerK said its not the actual engine temperature which will always be hotter.
If you fit a gauge first you will need to determine what is the normal operation range for your current cooling system and make a note of the high / low temperature reading. After this anything above or below this is an indication that you are operating outside it's normal range. It may not actual be an issue and how much higher you can go before failure is the unknown part, but at least you have the indication you wanted.
A low reading usually indicates you have lost your coolant.:laugh:
Once you have a gauge fitted it will become the focus of ever journey. I speak from experience as an ex Reliant Scimitar owner, gauge fitted as standard, overheating optional......:laugh: :silly:
The following user(s) said Thank You: Owl
16 Apr 2020 09:08 - 16 Apr 2020 09:08 #221125 by Max Headroom
Yep - I'd completely agree with that; remember that your car has a water pump and is pumping the coolant around the system.
(I have a 1930s car not fitted with a water pump, that relies solely on 'thermo-syphon' to move the coolant around, so getting stuck in traffic with such a car is a potential nightmare with no air moving through the radiator :S)
Last edit: 16 Apr 2020 09:08 by Max Headroom.
16 Apr 2020 17:35 #221137 by Lambert
Having had an obd2 display giving coolant temperature among other things it makes you completely paranoid about even one degree of variance outside what you consider normal and totally ruins the driving experience to the point where you can become preoccupied with it to the detriment of what is happening around you. This is why the dashboard guage is so inaccurate and only warns of a significant issue.
