SJ41x transfer case mounting kit supplier ?
09 Mar 2020 15:03 #219636
Replied by mlines on topic SJ41x transfer case mounting kit supplier ?
I had an SJ prop lengthened. We guessed at probably 10mm, basically enough for the prop to be fitted over the central flange nut on the transfer box flange end
The following user(s) said Thank You: Johnniehec, jackonlyjack
- X8GGY
09 Mar 2020 15:28 #219638
Replied by X8GGY on topic SJ41x transfer case mounting kit supplier ?
I made my own (albeit for a standard transfer box) using a cardboard template and then cut it out of steel plate with just an angle grinder and a welder, see here -
www.bigjimny.com/index.php/forum/18-buil...buggy-build?start=48
- Rabid Rhino
- Elite Member
- Thank you received: 33
09 Mar 2020 16:58 - 09 Mar 2020 17:23 #219647
by Rabid Rhino
Replied by Rabid Rhino on topic SJ41x transfer case mounting kit supplier ?
Went with the HM4X4 kit which was 400EURO but as of today, it went down to 327.87EURO. RESULT !!!!!
I cleared up the confusion (poor translation) that you don't need to buy a Samurai gearbox. (I couldn't understand why you would)
It looks the most complete kit out there as the mount resembles a Trail Tough's Mighty Kong II
Last edit: 09 Mar 2020 17:23 by Rabid Rhino.
09 Mar 2020 17:45 #219649
So you already have an SJ Transfer box?
- Rabid Rhino
- Elite Member
09 Mar 2020 18:02 - 09 Mar 2020 18:04 #219652
by Rabid Rhino
Yes, 410 & 413/Samurai
FYI, here are some gearing numbers numbers
Year T-Case Ratios High & Low Percentage over Mk1 Percentage over Mk2
1998-2005 1.32:1 & 2.145:1
2005-2018 1.00:1 & 2.002:1
SJ410 1.58:1 & 2.51:1 20% & 17% 58% & 25%
SJ413 1.41:1 & 2.27:1 7% & 6% 41% & 13%
Jimny Diff ratios
1998-2005 = 4.11:1
2005-2018 = 4.30:1 4.6% lower than Mk1
Tyre Sizes
Jimny 205/70/15 = 11.3 + 15 = 26.3"
2'' lift: 235/75/15 = 13.9 + 15 = 28.9" +10% over stock
3'' lift: 265/75/15 = 15.7 + 15 = 30.7" +17% over stock
So on a Mk1 Jimny
SJ/Samurai 413 will be pretty perfect for 29s
SJ/Samurai 413 & Mk2 Diffs will be pretty perfect for 30s
SJ410 will be pretty perfect of 31s
Jimny Diff ratios
1998-2005 = 4.11:1
Tyre Sizes
So on a Mk1 Jimny
Last edit: 09 Mar 2020 18:04 by Rabid Rhino.
09 Mar 2020 18:12 #219654
Replied by jackonlyjack on topic SJ41x transfer case mounting kit supplier ?
Nice if you're considering another gearing change to 4.16:1
you will need the final drive gear from the 413 box (i think)
If you go 6.5:1 you get a full set of new gears
Time to create page: 0.171 seconds
