1.5 or 1.6 VVT for engine swap - opinions
28 Feb 2020 18:00 #219189 by Riccy
No I never did any dyno stuff with the 1.6 grey Jimny, just modded and drove it. The amount of mods and 33" tyres made it rather underwhelming to drive on roads, more of a laning and off-road machine.
If your car is more standard you will find a big boost as you get more torque than expected, a welcome bonus. All the various engines avaliable to swap in easily are limited by the standard Jimny's ECU, intake and exhaust systems (if you want to keep stock wiring loom, sanity and money). This means it doesnt make much, if any, difference between an M15 and a M16 or even the M18 I have.
Currently im in Ulysses with the 1.8 and thats a dream, but still slower with 31" tyres than Sniper's well looked after 1.3 engine Jimny (albeit with a lot less weight and 215/75r15 tyres). New 2.5" zorst has helped, throttle bodies and ECU are next for it and that will be getting dyno tuned. Im hoping for a before and after run to see what difference the throttle bodies make :evil:
29 Feb 2020 10:16 #219218 by Keithy
I've been considering this type of ecu as an alternative to £800 on an MS3.......
Actually may be cheaper than a remap on the Jimny ecu....if it's even possible....just to bring the 1.6 fuel and timing into some sort of acceptable performance.....always an option to control the pwm on a vvt for a non vvt car too.
29 Feb 2020 11:47 #219220 by Lambert
Is that like an arduino based thing then?
01 Mar 2020 10:02 #219240 by Keithy
Lambert wrote: Is that like an arduino based thing then?
From the first line in the description....
The UA4C gets it’s name “Under Arduino 4 Channel”, as the Arduino Mega sits on top of the Speeduino PCB.
Non VVT jimny could have the 135hp SS1600 engine with full control of the vvt for £230
  • Tin Worm
02 Mar 2020 16:53 #219294 by Tin Worm
Replied by Tin Worm on topic 1.5 or 1.6 VVT for engine swap - opinions
Cheers Riccy, I was just wondering how the 160cc increase would feel, but seeing as I'm replacing a blown motor, I have nothing to compare it to!
Mother in law collected a 66k 1.5 VVT engine for me while she was in the North East.
It's now at my dads bolted to an engine stand waiting to have Jimmy bits bolted to it.
I collect the poorly Jimny on Saturday all being well!
Sunday is for pulling the poorly 1.3 out of the new car and see what's what!
  • Tin Worm
10 Mar 2020 13:58 #219681 by Tin Worm
The Jimny made it home on Saturday, albeit on a recovery truck.
Sunday we pulled the motor and stripped the Jimny ancillaries and mounts etc.
Stripped the Swift motor, add started building it up.
It's ready to drop in now, just need a couple of hoses as some of the coolant pipes look a bit soft.
Next Saturday it goes in, fingers crossed.
Time to create page: 1.620 seconds
