Hand brake "ON" light
12 Feb 2020 17:53 #218393 by yakuza
Replied by yakuza on topic Hand brake "ON" light
"just to remove the plastic center console between the seats. 2-3 screws PH2"
How can you tell it is the switch?
12 Feb 2020 18:29 #218397 by Riccy
Replied by Riccy on topic Hand brake "ON" light
mickt wrote: The last post is what I wanted as it is definitely the switch. Do the seats have to come out then?
no, just slide them forward as far as you can.
Theres 2x screws around the cup holder area. remove them and slide it a bit towards the rear before lifting up and over the handbrake handle ;-)
Theres a plastic tab that goes into a bracket so if you dont slide it back before lifting that snaps off.
  • mickt
14 Feb 2020 10:50 #218490 by mickt
Replied by mickt on topic Hand brake "ON" light
Champion Riccy.
The fluid level is OK and the pads and discs and callipers are brand new. This has been ongoing for sometime and it needs looking at now. It is intermittent by the way.
  • mickt
15 Feb 2020 10:17 #218518 by mickt
Spot on Riccy. So it is not a switch per se but a spring operated earthing connector. Not much to go wrong on it. But I hoovered a few dried leaves and removed the holder and plunger, cleaned all surfaces ensuring that the contact points were bright and shiny for contact and replaced, It is held on to its mounting point with just one PK screw.
Time to create page: 0.157 seconds
