Hand brake "ON" light
- mickt
11 Feb 2020 11:50 #218295
by mickt
Hand brake "ON" light was created by mickt
This light has a habit of staying on so how does the handbrake cover come off? Does it mean seats and carpet out? Also are the switches available?
- Thank you received: 1999
11 Feb 2020 15:33 #218309
Replied by Lambert on topic Hand brake "ON" light
Is there enough fluid in the reservoir our 16 did that with the level at about half between the marks.
11 Feb 2020 20:34 - 11 Feb 2020 20:35 #218328
Replied by yakuza on topic Hand brake "ON" light
coins falling down into the switch by the hand brake handle, loose wires, ignition key switch slack or loose,
you can try wiggle the key a bit.
faulty brake handle switch or on the brake fluid reservior.. reservoir switch can be tested by pressing the lid.
Mine never came off from a broken circuit inside the dashboard cluster. took me a while to find that.. Also the ABS central and a diode inside the dash can make it shine forever. according to the circuit diagram.
This has been discussed in several other topics, think i copied most of them into the topic I kept alive for a while
Last edit: 11 Feb 2020 20:35 by yakuza.
11 Feb 2020 20:37 - 11 Feb 2020 20:37 #218329
www.bigjimny.com/index.php/forum/7-jimny...brake-light-stays-on
think that one is the most extensive topic on the topic..
Last edit: 11 Feb 2020 20:37 by yakuza.
11 Feb 2020 20:41 #218330
ahh and switch by the handle is easy accessible just to remove the plastic center console between the seats. 2-3 screws PH2
- mickt
12 Feb 2020 13:34 #218378
by mickt
Replied by mickt on topic Hand brake "ON" light
The last post is what I wanted as it is definitely the switch. Do the seats have to come out then?
