Re:Re:Re:Oil in spark plug tube.
17 Dec 2019 20:10 #216530 by Wailin
Hi folks. I've noticed my Jimny misfiring recently on cold mornings and I put it down to old spark plugs as I hadn't changed them since I bought it. So I got down to the business and when removing one of the coils I noticed oil around it. Looking into the spark plug tube it had oil around the plug too. Looks like I found the cause of engine misfiring! I went ahead and changed the plugs anyway and it seems to be running ok. Am I in trouble with the oil leak? Could it be something serious? I haven't gotten the chance to check since but I'm guessing if I did check there will be fresh oil around the coil again.
The engine in my Jimny is a 1.6 from the Suzuki Liana btw.
18 Dec 2019 05:09 #216534 by Lambert
Replied by Lambert on topic Oil in spark plug tube.
Are we talking wet running oil or just a bit of a dark oily residue? When you undid the suspect plug did you notice it was especially easier to undo than the others?
18 Dec 2019 07:08 #216536 by mlines
Replied by mlines on topic Re:Oil in spark plug tube.
If it's like most of these then it's a simple failure of the spark plug gasket.
Different types depending on engine, here is the G13 one, I also sell an M13 one
www.bigjimny.com/store/spark-plug-gasket/seal-m13-engine.html
18 Dec 2019 09:03 #216540 by Wailin
Replied by Wailin on topic Oil in spark plug tube.
It's fresh engine oil Lambert, the plug was covered in it when removed. Only one plug so I'm hoping it's just the gasket.
18 Dec 2019 09:07 #216541 by Wailin
Replied by Wailin on topic Re:Oil in spark plug tube.
Hopefully it's just the gasket Martin. The engine is the M16a from a suzuki liana. Probably a long shot but you wouldn't happen to stock those?
18 Dec 2019 17:44 #216559 by Riccy
Replied by Riccy on topic Re:Oil in spark plug tube.
The liana 1.6 has the same spark plug gasket as the m13 jimny engine ;-)
Time to create page: 0.481 seconds
