Is there ANY advantage to vacuum hubs?
- Caelite
22 Nov 2019 19:25 - 22 Nov 2019 19:27 #215878
by Caelite
Replied by Caelite on topic Is there ANY advantage to vacuum hubs?
I've decided today after a few hours freezing my ass off trying to troubleshoot my 4WD system that I'm going to fit manual hubs to mine.
Out of curiosity, does anyone know the real difference between the AVM 457 and 457 High Performance (black vs red)?
www.ks-international.com/free-wheel-hub-manual-pair-6423.html
www.ks-international.com/free-wheel-hub-...air-manual-6424.html
Are the red ones worth an extra £30, also, KS international is the best place to get AVM hubs right? They seem a good 10-15£ cheaper than everywhere else.
Last edit: 22 Nov 2019 19:27 by Caelite.
22 Nov 2019 19:50 #215879
Replied by jackonlyjack on topic Is there ANY advantage to vacuum hubs?
I have the jimnybits cheap one's £100 ish no issues as yet
and i have pushed them hard off-road
Member sniper has AVM red one's fitted
22 Nov 2019 20:01 #215880
Replied by Riccy on topic Is there ANY advantage to vacuum hubs?
AVM Red tops have an alloy outer casing (instead of chromed plastic) and supposedly stronger internals. Mixed benefits in that the alloy casing isnt lacquered, meaning they corrode and dont look great after a year or two, and the extra strength would only be a need if running huge tyres.
KS mckenzie is the cheapest spot to get the red tops, probably the normal ones as well. Good quick service in my experience as well
22 Nov 2019 20:01 - 22 Nov 2019 20:08 #215881
by HUN
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
Replied by HUN on topic Is there ANY advantage to vacuum hubs?
I have red AVM hubs. I did think difference is the colour only. Plastic sounds dodgy for me.
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Last edit: 22 Nov 2019 20:08 by HUN.
- Thank you received: 1967
23 Nov 2019 09:53 #215887
Replied by Lambert on topic Is there ANY advantage to vacuum hubs?
My normal black tops are aluminium outers with plastic internal switching mechanisms. The actual locking components seem to be sintered powdered metal. My last set gave 5 years of service before a bearing surface failed. The polished aluminium will stay shiny until the first exposure to road salt then it dulls within the month.
23 Nov 2019 17:23 - 23 Nov 2019 17:24 #215901
by Scimike
Would have expected them to be fit and forget items.
Replied by Scimike on topic Is there ANY advantage to vacuum hubs?
Is that good or bad in comparison to other types or makes available?Lambert wrote: My last set gave 5 years of service before a bearing surface failed.
Last edit: 23 Nov 2019 17:24 by Scimike.
