Is there ANY advantage to vacuum hubs?
- Thank you received: 1967
23 Nov 2019 18:32 #215909
Replied by Lambert on topic Is there ANY advantage to vacuum hubs?
Good I think. They did 70 odd thousand miles.
25 Nov 2019 21:14 - 25 Nov 2019 21:15 #215966
by Bosanek
Replied by Bosanek on topic Is there ANY advantage to vacuum hubs?
Compared to manually operated free wheeling wheel hub heads, pneumatically operated wheel hub heads have two advantages:
1. Convenience of use - there is never a need to exit the vehicle to switch them.
2. Almost no risk of them freezing in very cold weather and thus not allowing to be (un)locked - due to requirements of achieving vacuum, they are much better sealed from the outside than manual hub heads are, reducing ingress of water which can later freeze.
Last edit: 25 Nov 2019 21:15 by Bosanek.
