I don't think the Jimmys got any brakes she said!
09 Nov 2019 19:32 #215522
by Scimike
Replied by Scimike on topic I don't think the Jimmys got any brakes she said!
As you plan to have a go:-
So this is the type to stay away from -
ebay.us/ppOj51
It will make a flare every 10th go that is almost acceptable, but for the most part I was not happy to use the resultant mess on my cars.
Eventually got this type, works every time and each flare is perfect. It's also good in tight spaces which means you can use it on lines attached to the vehicle. Note - you need to order the correct flare, picture just to show type.
ebay.us/w6I6mR
Other types exist which I am sure are just as good, but these have been a good addition to my toolbox.
Have fun
Mike
ebay.us/ppOj51
ebay.us/w6I6mR
Have fun
Mike
15 Nov 2019 00:12 #215639
by Fossie
Replied by Fossie on topic I don't think the Jimmys got any brakes she said!
Thanks for the advice, rain , sleet , puddles and time constraints meant I asked the local garage to have a look. He did it next day £65 all new lines fitted and bled up....brakes never been so good...result ! Would have struggled to match hat price myself.
As for flaring kit will still look into it for bike club tool box which we share amongst members. Ta!
13 Feb 2020 19:39 #218450
by Fossie
Dejavu.....not mine but my daughters is mirroring ours ...
To night she phoned from a car park in Buckingshire asking about a going soft brake pedal....yep on checking the brake reservoir it was on the minimum....moving it forward there was a patch under the drivers side , that'll be where the lines go and divide then.
Hers needed a bit of welding last month just like ours .
At least we know !
At least we know !
13 Feb 2020 22:40 #218472
by Fossie
Quick update , Robyn (daughter) found the leak ...corroded pipes. So she topped up the brake fluid , bent over the broken pipes back on their selves cable tied it .
Then drove it home steady with only th front brakes and gears the couple of miles ..
Old Skool.
Can't do that on one of yer new motors. She was obviously observing how ex army mechanics worked !
Old Skool.
14 Feb 2020 23:34 #218510
by Fossie
Now sorted the next day by a local chap £125 , new lines front to back.
I mention it in case someone else needs a gauge .
- Thank you received: 1999
15 Feb 2020 04:41 #218512
Replied by Lambert on topic I don't think the Jimmys got any brakes she said!
That's not a bad price, copper or steel line?
Time to create page: 0.546 seconds
