I don't think the Jimmys got any brakes she said!
08 Nov 2019 23:07 - 08 Nov 2019 23:08 #215491
by Fossie
I don't think the Jimmys got any brakes she said! was created by Fossie
So this evening the missus came home from the stables and said that she thought the brakes were not as good as they were in fact the warning light flashed on . The handbrake was fine though.
On checking the reservoir yep it was on minimum.....didn't take long to find the reason , yes the brake fluid was on the floor and along the chassis on drivers side.
I have searched this site but my question is where should I get replacement brake lines , how much and how much is it of a pig to do.
It is character building I know.
Last edit: 08 Nov 2019 23:08 by Fossie.
08 Nov 2019 23:38 #215493
Replied by jackonlyjack on topic I don't think the Jimmys got any brakes she said!
Most independent motor factors will make you one up
Price should be around £15
Just be aware they don't fit the wrong ends.you need fully threaded fittings
I they say other type will work IT will not
The following user(s) said Thank You: Keithy
- Max Headroom
- Banned
- Thank you received: 217
09 Nov 2019 00:07 - 09 Nov 2019 00:09 #215494
by Max Headroom
Replied by Max Headroom on topic I don't think the Jimmys got any brakes she said!
Hi Fossie
I rebuilt the brakes on my old MG Midget.
There are kits out there for some vehicles, but it was cheaper if I bought a flaring tool and cut my own from a length of Cupro Nickel pipe. Some kits are copper but its softer and probably easier to accidentally pinch, kink or crush.
The job itself was not difficult and I was able to route the pipes more neatly than the originals. Just don't overtighten the unions.
From memory, the tools I needed were:
A suitable sized pipe-cutter
A suitable sized pipe-bending tool
De-burring tool
Flaring tool.
Items needed:
Sufficient length of cupro nickel piping.
Sufficient amount of replacement unions and Tee-pieces
Sufficient amount of replacement rubber-lined P clips and support brackets
Bleed-tubes
Brake fluid
The biggest pain was trying to fathom out which type of flare was correct for my car - there are several. This is critical or you will simply get unions leaking. Several phone calls to various places eventually confirmed the correct flare tool needed.
Top tip - remember to fit the unions to the pipes BEFORE flaring the pipes!
De-burring tool
Flaring tool.
Items needed:
Bleed-tubes
Brake fluid
Last edit: 09 Nov 2019 00:09 by Max Headroom.
09 Nov 2019 08:54 - 09 Nov 2019 08:58 #215503
by Scimike
Replied by Scimike on topic I don't think the Jimmys got any brakes she said!
I can just confirm what Jack and Max have already said.
It's not a difficult job replacing brake lines, the first issue is to remove faulty line and hopefully this will happen without snapping or rounding off the pipe end in the cylinder / union.
Once removed you have all the information to order unions / pipes to make your own, Google the flare type (bubble or ISO?) and get the correct flare tool. Cheap universal £9 tools are useless, expect to pay £35 - £40 for a specific fixed tool. I can send link to good ones if you want to make your own, or send you my (cheap) universal tool for free if you cover the postage. This is not a good offer, it's useless.
I like making my own and like Max have classic cars which share the cost of the tools.
Alternatively take the removed pipe to a garage or motor factors and pay them to make one for you. It's a £10 - £20 option.
Bleeding the brakes afterwards is a two people job, or you need an ezybleed or vacuum bleeding system to help, so another thing to consider if you have never done this.
Or just pay a garage to sort your brake lines out, it's cold outside and maybe the better (if more expensive) option. I expect £20 in parts plus 1hr labour, so about £60 - £100 ???
I don't do garages so maybe my prices are out for this.
Good luck
Mike
Good luck
Mike
Last edit: 09 Nov 2019 08:58 by Scimike.
09 Nov 2019 09:13 #215504
by Fossie
Replied by Fossie on topic I don't think the Jimmys got any brakes she said!
Thank you all for the info, daylight should make it easier to find exact location or pipe but , both rear pipes will need doing .
The cold wet comment is a factor !
I have a vacuum pump and could probably do with a flaring kit away , but will stay away from the cheapo versions then.
So will remove old ones with crossed fingers and and a pray that it doesn't snap or collapse , so I measure follow etc .. Again ta!
Just when you thought it was going so well eh?
- Max Headroom
- Banned
09 Nov 2019 12:53 #215508
by Max Headroom
Scimike is quite right about the el-cheapo flaring tools - I should have mentioned I took an age reading reviews and looking at my options before making a decision.
If you can identify the right flare, you may be able to hire one rather than buy one if the cost can't be justified
Time to create page: 0.331 seconds
