98 Jimny Steering box rebuilding and kit.
01 Nov 2019 18:50 #215275 by kirkynut
If you were in the UK I'd suggest getting a second hand one.
They're very reliable, so what's the problem?
  • Jim Jim
01 Nov 2019 22:58 #215287 by Jim Jim
Replied by Jim Jim on topic 98 Jimny Steering box rebuilding and kit.
kirkynut wrote: If you were in the UK I'd suggest getting a second hand one.
Hey Mate,
Thanks for the reply.
Its leaking at the top between the box hosing and the "cover" where the adjustment screw is. I took off the four bolts, where were really tight, and discovered that there is a seal on the shaft which is where I suspect its leaking from.
It has no play, no grinding, just leaking fluid, even while idling.
Cheers
  • Megalife
20 May 2020 14:52 #222583 by Megalife
Replied by Megalife on topic 98 Jimny Steering box rebuilding and kit.
I appear to have the same issue, did you manage to find a solution?
Time to create page: 0.244 seconds
