1999 Jimny JLX Blown Head gasket
  • Owl
06 Oct 2019 23:54 #214385 by Owl
Hello, G13BB SOHC Engine
Popped a pin hole top radiator hose, engine overheated, had CO2 radiator test shows gases coming through, leaking head gasket. Engine was rebuilt 2000kms ago, no engine hoses were changed out?
Although this is an obvious loss of coolant problem, Are these Jimnys generally stable in the head gasket area, running them at 3500rpm on highway (90kms per hr) is pretty high rpm for sustained driving kinda worries me.
Is the head gasket on the G13BB engine a problem in these engines? Are they usually stable over the years? Is there anything I should be looking for as ill be doing the job myself? I will take the head in for skimming and crack assessment and valve testing. Head was reconditioned couple months ago.
Look forward to any advice. Owl
07 Oct 2019 00:13 - 07 Oct 2019 00:16 #214386 by Reason2doubt
Going off the history of my car which is extremely detailed - it's had two in it's lifetime (1999). One in 2008 and one just a few months ago (I bought it and changed it out of caution) - the one that was fitted in 2008 didn't seem to have any issues however so no doubt there was a bit more life in the gasket.
I used a kit off ebay and replaced a load of other bits in the rocker cover - I will say that the kit itself is a bit shite as the gaskets and other bits 'just fit' - they are close enough to fit, but just too poorly manufactured to fit properly. If you have the opportunity I would recommend a suzuki one out of convenience.
I hate revving mine past 3500. Been a long time diesel driver and this sounds aweful. Everyone keeps telling me that 3500rpm is fine though, so I'm getting into the habit of turning the radio up enough to drown out the engine scream and it's been running fine, if anything, it's got a bit more "go" at that rpm anyhow.
I got my head skimmed at the same time by a local garage. I was also recommended to buy new cylinder head bolts as apparently they can sometimes elongate a little with the heat and force - don't know if that is true or not, but for £15 I got some new ones of ebay just in case.
Hope some of that is useful!
Last edit: 07 Oct 2019 00:16 by Reason2doubt.
  • Owl
07 Oct 2019 01:37 #214389 by Owl
Replied by Owl on topic 1999 Jimny JLX Blown Head gasket
Thanks R-2doubt. 3500+rpm in these Aussie summers?, i dont think it will handle it but time will tell. I have to keep it for a couple years if possible as I've put too much into it. Thanks, about the head bolts, prob a good idea to get new ones, as I think the engine builder i used wouldn't have even used a torque wrench anyway and just bolted it up - tight. Rough as gutz! Will never use him again. I think the car is more suited for a small town city driving, or on a farm property, the highway i think will take this engine out in Aussie conditions. Or have I just had bad luck so far?
Ill price and source a genuine head and rocker gasket, not sure it would be good if Suzuki did a VRS kit, should get all the gaskets needed. i agree, the aftermarket kits a hit and miss unless you know which brands are the good ones.
Anyone know an aftermarket reputable VRS gasket kit for G13BB? If i buy it from the head services shop you'd hope they will sell you a decent kit. If i can get genuine at a reasonable price ill definately go that way.
i found from my experiences that aftermarket gaskets and those rocker cover rubber blocks and gaskets are made to a price and won't last long. A few years if your lucky. Oil seals , Ive learned the hard way with those, just pay extra and use good genuine seals if there's a lot of labour to get to them. Interestingly the tow truck driver who is a mechanic, and the mechanic who looked over my jimny says the later modern vehicles generally have less problems with head gasket failure, more computer, sensor and electricals.
07 Oct 2019 04:08 #214390 by Lambert
I don't have direct experience with the g series but they are generally very reliable and like the m series are designed for sustained periods of high rpm. Both these engines are small capacity petrol engines and the only way they are ever going to make power and torque is by using revs, its just how they work.
  • Owl
07 Oct 2019 07:44 #214395 by Owl
Thanks Lambert, I hope your right, otherwise I'll be wrecking it for parts. Gearbox is reconditioned, as good as new should be worth a bit.
07 Oct 2019 08:07 #214396 by mlines
The G13BB engines have a bit of a reputation of an oilway near No.4 Cylinder (rear of engine) blocking up causing local overheating and even camshaft failure. The local overheating distorts the head. I recommend frequent oil changes with good quality oil and the engine then seems to last forever.
The following user(s) said Thank You: Owl
Time to create page: 0.168 seconds
