INOX in new Jimny Lead-Acid Battery (JIS). It works!
- Thank you received: 627
28 Apr 2019 19:19 #206869
INOX in new battery was created by Soeley
Why do you need to check/charge the battery on a new car so often? Are you just doing lots of short stop start journeys and the battery isn't getting chance to charge up on a long run?
28 Apr 2019 19:40 #206873
Replied by Soeley on topic INOX in new battery
What a bout a battery tender then? Just keeps it on trickle charge and maintains the battery.
29 Apr 2019 13:54 #206903
by Gadget
Replied by Gadget on topic INOX in new battery
Is the battery not sealed? I've not checked, just assumed it would be. I'd be very surprised if the battery in a new car needs frequent charging. 90% of my journeys are a 2 mile trip to the station and back each day and I've never had a problem with battery drain, even on 10 year old cars in the depth of winter
29 Apr 2019 14:33 - 29 Apr 2019 14:38 #206908
Replied by mlines on topic INOX in new battery
Its been years since I have seen a battery that is not sealed for life (including my Gen 3 Jimnys), Therefore I took a quick look at the underbonnet photos of the Gen 4 I test drove and yes it has an old style battery. They really have taken the retro look to heart with this one!
Last edit: 29 Apr 2019 14:38 by mlines.
29 Apr 2019 14:38 - 29 Apr 2019 14:39 #206909
See 2 minutes 31 seconds
Last edit: 29 Apr 2019 14:39 by mlines.
11 May 2019 10:43 #207720
by facade
Replied by facade on topic INOX in new Jimny Lead-Acid Battery (JIS).
Let us know how it goes.
I remember in The Olden Days motor factors sold tubes of "de-sulphation tablets" that never worked, but that was most likely because the problem wasn't sulphation, but shedding of active material and disintergration of the plates.
The internet consensus seems to be adding saturated epsom salt solution (magnesium sulphate) and trickle charging will remove existing sulphation, but I've not found the chemistry behind it. The best way to prevent sulphation is to keep the battery charged.
Time to create page: 0.504 seconds
