Re:Jimny won't start - starter motor / immobiliser?
- rfenwick
27 Apr 2019 15:06 - 27 Apr 2019 15:08 #206772
by rfenwick
Jimny won't start - starter motor / immobiliser? was created by rfenwick
Hi,
I've just bought a 2003 Suzuki Jimny. It's been driving fine for the past few days and we were getting on so well...
I drove it home this morning and parked up, all fine. Got into drive it this afternoon, put the key in the ignition and tried to start the car - all the dashboard lights came on as usual, but it would not start at all. Absolutely no noise from anything mechanical - total silence. No obvious error lights on the dash.
Could this be the immobiliser? The car came with two keys - an official suzuki key, and a shop-cut copy. I was using the copy to start the car (though now neither key words). When I switch the car's power on, the immobiliser light comes on and stays on but I think is is normal until the car is started?
I have charged the battery up for good measure - it was a little on the low side voltage wise, but nothing major.
Or it's been suggested to me it could be the starter motor, and I should get underneath, find it, and give it a whack with a hammer.
Any advice gratefully received! (Or I could just whack myself with a hammer - kinda feel like it tbh...)
Thanks
Thanks
Last edit: 27 Apr 2019 15:08 by rfenwick. Reason: Wit
27 Apr 2019 15:24 #206773
Replied by mlines on topic Re:Jimny won't start - starter motor / immobiliser?
With an immobilizer problem the car still turns over.
The following user(s) said Thank You: rfenwick
- jwb
27 Apr 2019 15:37 #206778
by jwb
Replied by jwb on topic Re:Jimny won't start - starter motor / immobiliser?
Our 2000 M13A having similar problem.
Turn key and nothing.
New starter motor a year ago
Called for a tow and started fine when the truck arrived!
Will work through all the electrical cables earths etc and report back.
- rfenwick
27 Apr 2019 16:30 #206783
by rfenwick
Replied by rfenwick on topic Re:Jimny won't start - starter motor / immobiliser?
Will be interested to hear what you find jwb- you're obviously more technically capable than I am!
29 Apr 2019 05:48 #206881
by kirkynut
Replied by kirkynut on topic Re:Jimny won't start - starter motor / immobiliser?
Can you check the battery voltage?
If the battery seems fine, yes, whack the starter as the Solenoid might be stuck. It usually clicks though. So I think that the battery has expired but you need to check it first.
- Max Headroom
- Banned
- Thank you received: 217
29 Apr 2019 16:49 #206918
by Max Headroom
Replied by Max Headroom on topic Re:Jimny won't start - starter motor / immobiliser?
I'll second whacking the starter motor with a hammer - if youhave one of those lead-shot filled hammers - even better.
Got my friends Austin Seven started the other day doing exactly this. Dismantled the starter and oiled the bendix later - never sticks now
Time to create page: 0.147 seconds
