Light bar wiring diagram
- TaterTot
20 Aug 2018 20:41 #195307
by TaterTot
Replied by TaterTot on topic Light bar wiring diagram
Isn't the 3 option supposed to be automatic on with the high beams? Or do you also want the option of not having the bar on, while the high beams are on?
- Jimny1990
20 Aug 2018 20:58 #195308
by Jimny1990
Replied by Jimny1990 on topic Light bar wiring diagram
Along these lines
- TaterTot
20 Aug 2018 21:14 #195309
by TaterTot
Ah yes. That is pretty much the same. Difference from what I described is that it's a manual operation to switch between mode 1 and 3, and you have the option of keeping the bar off, even when high beams are on.
Both options are available with what you have as harness. But you will need either a new button, an extra relay, or both. The Diode he uses is an OK idea to have there, just to make sure nothing goes wrong.
You just have to decide exactly what you want, and what functions in each step. 1 and 2 you have defines, just not fully defined the 3.
- TaterTot
21 Aug 2018 09:34 #195321
by TaterTot
I have a question for you. How do you plan to use this, most of the time? Is it that i comes on when you turn the high beams on?
Time to create page: 0.311 seconds
