Light bar wiring diagram
- Jimny1990
20 Aug 2018 19:51 - 20 Aug 2018 19:51 #195301
by Jimny1990
Light bar wiring diagram was created by Jimny1990
Evening chaps
I have bought the below wiring kit from eBay, with the intention of wiring a LED light bar to my jimny.
I wanted it so I had 3 options. 1st On, 2nd off and 3rd on when the high beams are is on.
Looking at the wiring diagram, will I have high beam option ? Or is this the wrong type of switch.
Thanks
Thanks
Last edit: 20 Aug 2018 19:51 by Jimny1990.
- TaterTot
20 Aug 2018 19:53 #195302
by TaterTot
Replied by TaterTot on topic Light bar wiring diagram
Just to make sure I understand.
1. You want ONLY the light bar
2. OFF
3. Turns on together/with the high beams
Is this correct?
2. OFF
Is this correct?
- Jimny1990
20 Aug 2018 20:01 #195303
by Jimny1990
Replied by Jimny1990 on topic Light bar wiring diagram
That's correct mate
- TaterTot
20 Aug 2018 20:22 #195304
by TaterTot
OK.
That means you have option 1 and 3 in an OR state. It means that if you trigger either those conditions, the bar should be on. It also means that if you trigger both at the same time, you should still have the bar on.
It is fully possible to do with that kit there, at least from what I see from the pictures, the loom is just based on the switch only. What you can do is parallel connect the switch, with a relay (Open state gate), and control the relay with the switch on from the high beams.
Think of it like this: You have two switches, side-by-side, where either of them turns on the bar. If both are on, still on. Now one switch is replaced by a relay, that is hooked up to the high beams over the control terminals on the relay.
Does it make sense?
Does it make sense?
- Jimny1990
20 Aug 2018 20:34 #195305
by Jimny1990
Thank you for your reply. Would I not need a 5 pin switch for this?
- Jimny1990
20 Aug 2018 20:40 #195306
by Jimny1990
Time to create page: 1.107 seconds
