Rear wheel bearing and retainer question
20 Jun 2018 07:45 #193655 by LM42
hello all
please help!
need to change the rear axle seals, and bearings , have read a lot on how to get them off, the axle , but how do you get the bearing on and the retainer?
  • TomDK
20 Jun 2018 08:48 #193660 by TomDK
Replied by TomDK on topic Rear wheel bearing and retainer question
With a piece of tubing and a hammer.
Helps a bit putting the shaft in the freezer and heating the bearing a retainer a bit.
20 Jun 2018 10:09 - 20 Jun 2018 10:10 #193664 by yakuza
Did this on my SJ but same design. Careful with heating the bearing, you can heat it in your stove at max 100 C cause it is not so tight. the shaft you can put in the freezer over night. the retainer you can heat a lot to 200 or so C degrees.
Do keep everything ready like a proper long enough piece of tube that fits, and a large persuader (hammer) at hand, because as soon as the retainer touches the cold shaft it will cool down fast. Mine got stuck half way down and needed serious force to come all the way down on the shaft.
remember to let it cool to normal temp before you insert it into the new sealing.
Last edit: 20 Jun 2018 10:10 by yakuza.
20 Jun 2018 17:41 #193676 by Riccy
I take mine to a local garage, £10 usually gets them bunged on with their very large (and very old) hydraulic press. No heating or cooling, just a coffee while i wait usually :laugh:
  • helijohn
20 Jun 2018 19:07 #193683 by helijohn
Replied by helijohn on topic Rear wheel bearing and retainer question
Riccy wrote: I take mine to a local garage, £10 usually gets them bunged on with their very large (and very old) hydraulic press. No heating or cooling, just a coffee while i wait usually :laugh:
Me too.
22 Jun 2018 11:24 #193731 by safari
With a piece of tube and a good hammer.
very easy job
if u worry u die if u dont worry u still die so why worry
Time to create page: 0.286 seconds
