Auto transmission assistance needed
- jwb
09 Jul 2018 07:23 #194130
by jwb
Replied by jwb on topic Auto transmission assistance needed
Definitely M13A apparently at some stage in 2000 it changed. Not sure of the build date. I found out when I needed to replace the rocker cover gasket.
- Thank you received: 226
09 Jul 2018 07:26 #194131
by zukebob
Replied by zukebob on topic Auto transmission assistance needed
beat me to the reply.
09 Jul 2018 07:59 #194132
by zukebob
Maybe I should simply answer "no".
Physically fitting the transmission should be possible. The mounts are likely different. You would want to confirm that the early Jimny M13 and the later VVT used the same flywheel. Interfaces for the transmission control modules and yours are a bit different and that would need to be worked out. All of the issues should be able to be overcome but at a cost. Probably best to keep looking for a decent condition A174.
Was the rebuild out of the question?
- jwb
09 Jul 2018 22:59 #194150
by jwb
Looking at the rebuild option. It's not cheap. Jimnys are not very common in Australia so finding a used A174 transmission is hard to come across as well.
It's a good way to learn about the car and we figure if the transmission is re-built we'll get some good years out of the rest.
My other cars are Land Rovers so quite used to being a mechanic!
10 Jul 2018 06:29 #194157
by zukebob
I think others on the forum will relate to that comment.
If you are in Australia, and decide on a shop's help, you may want to become a part of the Auszookers forum at:
www.auszookers.com/forum/index.php?sid=0...bc90da75a461cb5944ac
Members could probably provide some suggestions on where to take it.
If you are going to take a crack at it yourself, you could go with the kit you mentioned and could probably get any other parts from Martin (mlines).
I'm glad the transmission problem hasn't discouraged you. Good luck.
Time to create page: 0.506 seconds
