How to Plug Vacuum Pipes
01 Apr 2018 11:51 #191132 by mlines
Replied by mlines on topic Re:How to Plug Vacuum Pipes
Shorting the wire means the 4wd light doesn't flash, it comes on solid when 4wd is selected. It is really needed for the push button jimny's otherwise it will never select 4wd
  • Mraz
01 Apr 2018 13:06 #191138 by Mraz
Replied by Mraz on topic Re:How to Plug Vacuum Pipes
Bosanek made a good article on this subject, look for it on Jimny wiki.
I removed entire vacuum system from my Jim and it works like a charm. Just shorten the vacuum sensor and unplug everything. And block the pipes on hubs as mentioned. Mine is a 2006 peteol.
01 Apr 2018 13:09 #191139 by furo
Replied by furo on topic How to Plug Vacuum Pipes
Martin - thank you. Mine has a manual transfer case - is shorting it still recommended?
Mraz - thank you, I did read the wiki but I just wanted to be clear as I tend to mess things up!
  • helijohn
01 Apr 2018 20:10 #191152 by helijohn
Replied by helijohn on topic How to Plug Vacuum Pipes
furo wrote: Martin - thank you. Mine has a manual transfer case
Mine was.;)
01 Apr 2018 20:50 #191155 by mlines
Yes, short it and then you have a nice working 4x4 light
  • florinelu07
02 Apr 2018 07:38 #191170 by florinelu07
Replied by florinelu07 on topic Re:How to Plug Vacuum Pipes
If you are "lucky" enough, you'll get the Jimny with the vacuum switch already with short/bridge to fool the vacuum system (mine was .... only 2wd was functional).
Sorry for the off topic, but I would recommend to add to the Jimny buyers guide, the inspection of the switch short if still has vacuum hubs.
Time to create page: 0.178 seconds
