R72 Gearbox Output Shaft Bearing Removal
05 Apr 2018 08:31 - 05 Apr 2018 08:37 #191311 by Max Headroom
Thanks OlaGB & Yakuza.
I guess I'm still non the wiser about whether new bearings will fix the problem ;) Keeping it topped up properly with fresh oil seems to be all one can do.
I had my g'box drained down and refilled (but not flushed) There were metal particles present, but I dont know how much or how big they were as unfortunately I wasn't shown. (In aviation, we have magnetic plugs on engines or g'boxes and any particles go off for spectral analysis to determine where in the component the metal is coming from which helps determine the remaining life and functionality of that component, and avoids future component failure while in use)
At the moment I have no perceptible bad noises coming from the g'box, but then the car is that damned loud (soft top Jimny) I cant hear much anyway! :laugh:
My only worry is that I sometimes feel a bit of difficulty getting it into first or reverse gear; it just doesn't feel very positive; then when I lift my foot on the clutch I think "yep I didn't think that was fully engaged :dry: " but this may be a separate issue
Is the g'box plug magnetic? if not, I will attach a very strong earth-magnet to it to keep any metallic debris in one place
Last edit: 05 Apr 2018 08:37 by Max Headroom.
05 Apr 2018 12:06 #191317 by Busta
I believe the issue is entirely due to lubrication, hence the replacement bearings often being a sealed type. I'd be very surprised if it was related to the load on the bearings. Many people are running bigger engines with these gearboxes and we see no evidence of this accelerating the wear or causing premature failure.
Also the problem does not seem to be present in the more recent Jimnys (I believe Suzuki fixed the problem around 2008/9?), even though they are still using the same gearbox.
The following user(s) said Thank You: Max Headroom
  • ZukracerV6
05 Apr 2018 12:28 #191318 by ZukracerV6
Replied by ZukracerV6 on topic R72 Gearbox Output Shaft Bearing Removal
Yes the drain plug is magnetic. Mine was covered in fine mettalic swarf and parts of the bearing cage.
05 Apr 2018 18:10 #191338 by Riccy
Some people attribute the problem to a leak from the intermediate prop on early VVT models. This was the cause of my R72 failure initially
05 Apr 2018 18:20 #191339 by Max Headroom
Thank you Zukracer, Busta & Riccy :)
My Jimny knowledge is ever being increased!
Although debris was found in my g'box and its making no nasty noises (that I can tell) , at least not yet at any rate, what would be the best thing to do bearing in mind that this is my daily drive to work...
Should I hold tight and hope that no bad noises start and if they do, deal with it then?
Or should I find a convenient moment to get the g'box stripped down and the offending bearings replaced before they fail? I am assuming that they are going to fail at some point; unfortunately I dont have much history with this car other than service stamps in the book mostly from some Ford dealer.
05 Apr 2018 18:35 #191343 by Riccy
Run it and keep checking everything for leaks! The prop leak is from a bad glue seal on the gearbox end connection cap.
Redline MTL oil is commonly used to try and make shifting easier. Its normal to sometimes need a second go on the clutch pedal to get going. The clutch cable could be worn/out of adjustment, worth checking maybe?. its easy to adjust. plastic cover on the side of the gearbox with a plastic nut on the outside where it goes in. cover just pulls off.
Time to create page: 2.512 seconds
