Front Wheel Bearing - broken breaker bar - reverse thread nuts
  • 4x4dreckly
30 Dec 2017 19:08 - 31 Dec 2017 09:05 #187905 by 4x4dreckly
Hi Forum, finally got around to changing the front wheel bearing on my 52 plate O2, well that's what I thought!!!
Broke a breaker bar using the correct tool, so 2 questions please:-
1. is the drivers side wheel nut a reverse thread (UK car) - would doubt it.
2. Will heat form a blow torch on the bearing housing damage anything else on the hub assembly like seals etc...?
Thanks in advance
Mark
Last edit: 31 Dec 2017 09:05 by 4x4dreckly.
30 Dec 2017 20:16 - 30 Dec 2017 20:19 #187907 by mlines
It's standard thread. You did undo the retaining tang didn't you?
Sent from my Nexus 6P using Tapatalk
Last edit: 30 Dec 2017 20:19 by mlines.
  • 4x4dreckly
31 Dec 2017 09:04 #187922 by 4x4dreckly
Thanks for the confirmation re thread, do you mean tag not tang? If so yes I've released the tag on the retaining ring as shown in the picture.
  • 4x4dreckly
31 Dec 2017 09:09 #187924 by 4x4dreckly
So is the retaining ring seperate to the nut I.e. Release the tag then undo the ring, or is the retaining ring part of the nut??
31 Dec 2017 10:54 #187926 by mlines
All one piece, whereabouts in the country are you as someone may have a rattle gun they can use on it
Time to create page: 0.282 seconds
