Jimny not starting following body change
28 Aug 2017 17:55 #183727 by facade
Forgive me if I'm only now stating the obvious, but you have swapped the ignition barrel or the whole lock from the old one so that the key matches the ecu & immobiliser...
  • Tom1357
29 Aug 2017 09:31 - 29 Aug 2017 09:31 #183741 by Tom1357
Replied by Tom1357 on topic Jimny not starting following body change
I sorted this by changing loom and coloum over on the weekend.
I changed over my steering coloum so it's all my original truck, so I can turn my original key in the barrel, which has the correct chip in it for the ecu and immo box, and all starts.
facade - I did have my original key in the pickup ring yeah, which I'd pulled away from the barrel to make sure it picked up my key not new key which was in the barrel being turned, but the pickup looked different and I couldn't swap over as the wiring was different on the loom. And the wiring for the immo box was different so I don't think it picked that up right either.
With the new loom in, entire coloum pick etc, it starts! :) Turns out it's a little more time consuming to put a loom in neatly than it is to pull out an old loom! :(
I'll pop some pics up on my progress thread once it's looking a little more together
Thanks for the help guys
Last edit: 29 Aug 2017 09:31 by Tom1357.
  • helijohn
29 Aug 2017 11:05 #183749 by helijohn
Replied by helijohn on topic Jimny not starting following body change
Look forward to that. Well done with the switch over.
Time to create page: 0.147 seconds
