Jimny not starting following body change
- Tom1357
24 Aug 2017 08:29 #183613
by Tom1357
Jimny not starting following body change was created by Tom1357
After some pointers here, my jimny (1999 g13bb) shell was really very poor, I wanted to put some sort of roll bar on her, then the opportunity to have a fully caged tray back chassis and solid body (2004 reg) came up, so I went for this, cost less than the metal to make a cage let alone the time to try and fix my shell which I think is too far gone anyway.
Idea being, transfer my axles, engine, suspension etc over, and for less work I have a caged truck with a solid body.
We've done most of the work but the engine won't start, turning over fine but no spark and it's flashing the engine management light pointing to a immobiliser fault.
Truck is currently using my engine, ecu, wiring loom, but the interior loom is from the later truck and the wiring looks a little different, the pickup ring looks different and the plug for the additional little immobiliser box thing is different on the new truck , I can plug my older little immobiliser box into the wiring, but the plug doesn't use all pins so can't be right.
Has anyone ever done this swap? Am I best trying to just get the immobiliser removed completely off my ecu, or swapping my interior loom/dash from my old truck into new? I'm assuming once my loom is over, all looms will be from old truck, as will ecu, engine etc, so should work.
I'm struggling to find much info really, as most who swap engines obviously keep the year/engine type similar to keep it easy and to avoid these issues!
24 Aug 2017 10:07 #183616
by Jezz
It's been fettled just a tad.
Replied by Jezz on topic Jimny not starting following body change
If you have swapped the ecu. you will also need to swap the other associated electrics, as they are all coded together.
I don't think you can delete the immobiliser from the ecu?. I could well be wrong though.
Hopefully someone will pop up to confirm or tell me i'm typing rubbish shortly.
- Tom1357
24 Aug 2017 12:02 #183618
by Tom1357
Replied by Tom1357 on topic Jimny not starting following body change
Yeah that's what we've done, we also brought over the ECU, immobiliser box thing, key with chip, but the wiring on the truck has a different plug for the immobiliser box thing and the pickup ring looks different so I don't think they will pickup and process the chip right
24 Aug 2017 18:00 #183637
by Jezz
Pick up ring is coded to the ecu, so you will need the one from the car the ecu was taken from +keys +ignition switch and assciated wiring as it's all coded together. As far as i'm aware you cannot mix and match it. I could be wrong, And i'm sure someone will kick in and tell me if i am.
Or your other option is to buy an after market ecu and all those issues disappear.
25 Aug 2017 11:56 #183664
by facade
Replied by facade on topic Jimny not starting following body change
Just swap the interior loom and dash/switches etc over so you end up with your old car complete, but the tinwork from the new one.
It will be quicker than trying to sort out a fix to the hybrid one.
28 Aug 2017 07:48 #183720
by kirkynut
What he said! This is what I did when I performed the same job on a Vauxhall Nova years ago. I swapped a pre facelift into a Facelift shell and just adapted the wiring for light plugs etc to suit. Easier than mixing two looms but I think less has changed on Jimnys, so you might not have much if anything to do.
Replied by kirkynut on topic Jimny not starting following body change
facade wrote: Just swap the interior loom and dash/switches etc over so you end up with your old car complete, but the tinwork from the new one.
Time to create page: 0.538 seconds
