JImny sway bar disconnects?
  • Mraz
11 Apr 2017 13:17 #180127 by Mraz
JImny sway bar disconnects? was created by Mraz
Hi guys.
I removed my sway bar today to try driving without and see how it copes. Well, it drives like a boat!! I like it for off road bot on road it's just awful. Did anyone put sway bar disconnects on a Jimny and how did he do it?
11 Apr 2017 13:33 #180128 by X8GGY
11 Apr 2017 15:49 #180133 by X8GGY
Replied by X8GGY on topic JImny sway bar disconnects?
Someone else suggested just disconnecting one side's drop-link off the axle and tie it out of the way for offroad use, and for onroad use just bolt it back up again? ;)
  • 1066Boy
11 Apr 2017 16:39 #180140 by 1066Boy
Replied by 1066Boy on topic JImny sway bar disconnects?
I just took mine off and never looked back. Yes its a bit different on the road at speed but no worse than the removal truck I drive for work so I suppose I am just used to it. :)
  • Mraz
11 Apr 2017 18:57 #180148 by Mraz
Replied by Mraz on topic JImny sway bar disconnects?
First I was thinking of somethinig like S200KYS said but now im thinking I'd rather put some quick disconnect tie rods secured with a pin, something like these:
www.google.hr/imgres?imgurl=http://www.r....i&w=374&h=300#spf=1
Problem is I have no idea how this "tie rod end part" is actually called and how to translate it to Croatian so I can call SKF and order some.
12 Apr 2017 04:05 #180161 by Lambert
Replied by Lambert on topic JImny sway bar disconnects?
Those are called rose joints. Be careful with them as they have no give at all so any force they experience is transferred directly to what they are fixed to which isn't always a good idea. Also they're notoriously loud once they gain a bit of wear.
Time to create page: 3.919 seconds
