Engine miss firing and warning light flashing on, also fumes smell of rotten egg
- Rowland
07 Apr 2017 09:54 #180016
by Rowland
Engine miss firing and warning light flashing on, also fumes smell of rotten egg was created by Rowland
Thanks to your great advice on here a couple of years ago we bought a Jimny to use for our Farm vehicle to replace a Polaris Ranger and it has been excellent. However a couple of weeks a go when seeing the stock it started miss firing and cuts out as soon as you take your foot off the accelerator. When it surges the check engine light flashes. The exhaust fumes smell of rotten eggs and sounds a bit deeper than normal.
Anyway I opened the bonnet to see if any leads had come off and it all looked fine - started it again and it was back to normal!
This morning it has started again and the trick of opening and closing the bonnet hasn't worked! Any ideas?
Thanks
Thanks
07 Apr 2017 12:06 #180022
Replied by mlines on topic Engine miss firing and warning light flashing on, also fumes smell of rotten egg
Sounds like the catalytic converter on its way out
- Rowland
07 Apr 2017 19:05 #180044
by Rowland
Replied by Rowland on topic Engine miss firing and warning light flashing on, also fumes smell of rotten egg
Would that cause the problem to be intermittent? We have used it for about an hour tonight and it was like it to start with and then it was ok after 10 mins and fine when we finished with it. Can I just cut the cat out and replace it with a bit of straight pipe?
07 Apr 2017 19:56 - 07 Apr 2017 19:57 #180045
Replied by Daniel30 on topic Engine miss firing and warning light flashing on, also fumes smell of rotten egg
Yeah if your just using it on private ground cut it out if not it might fail an mot on emissions
There is two on the jimmy I think
Last edit: 07 Apr 2017 19:57 by Daniel30.
- DINGLE287
07 Apr 2017 21:40 #180050
by DINGLE287
Replied by DINGLE287 on topic Re:Engine miss firing and warning light flashing on, also fumes smell of rotten egg
Sounds like cat failure to me also. The best way to describe it is like trying to squeeze ice water out of a bottle the fragments that are breaking up inside the cat move around and intermittently block the flow. Jimnys also have a smaller pre-cat in the manifold which has probably broken up and is blocking the main cat. Abit of open surgery and welding should sort it.
Sent from my SM-N9005 using Tapatalk
- Rowland
08 Apr 2017 05:40 #180053
by Rowland
Replied by Rowland on topic Re:Engine miss firing and warning light flashing on, also fumes smell of rotten egg
Thank you for your advice
Time to create page: 0.533 seconds
