Re:Front Fog Lights
06 Mar 2017 14:33 #178876
by Bosanek
Replied by Bosanek on topic Front Fog Lights
As far as I know, the fog lamps themselves and the wiring should be the same for any Jimny (1998-2017).
It's the fog lamp brackets (mounts behind the front bumper) which differ according to front bumper generation.
So, just obtain the fog lamps together with the wiring and the brackets from a Jimny which has/had the same bumper model as yours.
- Michael01474
09 Mar 2017 06:24 #178999
by Michael01474
Replied by Michael01474 on topic Front Fog Lights
Ok, so I now have a set of OEM fog lights thanks to James. The engine bay wiring seems pretty simple but I need a bit of help with the switch wiring. I understand where the pink wire with the bullet connector needs to plug in but what do the blue, brown and black wires connect to. Any help appreciated.
09 Mar 2017 09:23 #179000
Replied by yakuza on topic Front Fog Lights
My 2005 jimny had all the wiring needed, i found the connectors behind the headlights. Only needed the metal brackets inside front bumper and the switch and of course the lamps. i bought the cheapest lamps i could find on ebay and they are really bad. horrible.
Brackets bought from the Suzuki dealer, original. Not too expensive.
11 Mar 2017 17:06 #179077
by Casey
Replied by Casey on topic Front Fog Lights
Take the live off the headlight so the fog's only come on when headlights are on. Run it through a fuse and a relay and run negative to earthing point on the body behind battery. Connect the switch to the relay.
Type wiring fog lights into Google and you'll find some diagrams.
11 Mar 2017 17:09 #179078
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Front Fog Lights
I'll look in mine in a minute. I'll let you know
Grey pick up Jimny
11 Mar 2017 17:25 #179080
by j999pre
Grey pick up Jimny
Ok. In mine the blue and the brown from the switch go to the red with a yellow stripe. The black is earthed. The bullet goes to the female bullet hanging out of the fire wall grommet on the inside.
Grey pick up Jimny
Time to create page: 4.598 seconds
