Confirmation - The "longer" spring is the front drivers side on RHD - Correct?
- TomDK
So a more correct name would be jimnybits lift kit
- Thank you received: 923
TomDK wrote: Not really. Since Pro Comp don't make lift kits for the Jimny. The shocks are made for some unknown US truck. Just happens to fit on a Jimny.
So a more correct name would be JimnyBits lift kit
I knew we'd agree one day, ... eventually Tom
Dave :kiss:
- 1066Boy
TomDK wrote: pro Comp don't make lift kits,
Now that is a sensible suggestion.
- Thank you received: 683
Jack
- TomDK
Dave :kiss:
Thanks Dave.. You're a good man
I'm sure we agree on lots of things.. Just, there's no reason to discuss 'em
mlines wrote: A STANDARD JIMNY has the same springs on each side at the FRONT and different springs left and right on the REAR.
An additional note on this Martin's statement: It is correct for RHD Jimnys ONLY.
LHD Jimnys have identical rear left and rear right coil springs, and they are different from both the rear left and from the rear right coil spring which are used in RHD Jimnys.
The front coil springs are the same both for LHD and RHD Jimnys though, and they are also the same front left and front right.
