02 sensors - engine management light on
  • susie
12 Jan 2017 20:45 #176706 by susie
Replied by susie on topic 02 sensors - engine management light on
How do I look for vacuum leak?
  • susie
12 Jan 2017 21:56 #176715 by susie
Replied by susie on topic Re:02 sensors - engine management light on
Ok thanks so I will have to take it to a garage and ask them to check for the vacuum leak? Is that easy to fix does anyone know or is it hard to tell?
Could it not be oxygen or o2 sensors then?
  • susie
12 Jan 2017 23:41 #176729 by susie
Just found a YouTube video which shows exactly what happens to me when I drive and my car cuts off when I stop at traffic lights or in a traffic jam.
  • jim
13 Jan 2017 00:08 - 13 Jan 2017 00:51 #176730 by jim
Hi Susie, this sounds very much like what I had recently and it seems to be a common query. It occured after having to have my gearbox fixed which was expensive and like you I was sick of throwing money at it.
What fixed the issue for me was replacing both of the two ignition coils, heat from the engine may be the culprit over the years. The shuddering and drop in revs particularly when at traffic lights (probably as the engine got warmer) had stopped.
Last edit: 13 Jan 2017 00:51 by jim.
  • susie
13 Jan 2017 07:23 #176733 by susie
Thanks.
How much does it cost to replace ignition coils do you know?
Thank you
  • jim
13 Jan 2017 10:48 - 13 Jan 2017 10:55 #176736 by jim
susie wrote: Thanks.
Thank you
There is a member on here called j999pre he sells a lot of used parts and I have had several from him. If you message him on here he may have some used but perfectly working ignition coils. This will be a lot cheaper than new and will help you rule out the cause of the power loss.
Another member on here had the same issue and replaced them with new cheap ebay ones which worked perfectly.
Other possible causes of intermittent power loss include , A blocked exhaust catalytic converter, camshaft sensor or crankshaft sensor (earlier jimnys don't have one).
From my experience of power loss I'd try the coils first.
Last edit: 13 Jan 2017 10:55 by jim.
