2006 Stereo stuck CD
  • Daniel30
15 Dec 2016 08:31 #175670 by Daniel30
Replied by Daniel30 on topic 2006 Stereo stuck CD
Don't tell your insurance company your listening to that they will put up your insurance premium :laugh:
  • NicBeeee
15 Dec 2016 13:41 #175684 by NicBeeee
Replied by NicBeeee on topic 2006 Stereo stuck CD
The worst thing is it is surprising how many times I get in the car to drive home from work and Bon Jovi comes on the radio, there is no escape, I might end up taking a sledge hammer to the stereo with it still in the car if I dont get around to sorting it soon.
  • Daniel30
15 Dec 2016 17:06 #175691 by Daniel30
:woohoo: :woohoo: :woohoo: :woohoo:
  • NicBeeee
13 Mar 2017 16:13 #179165 by NicBeeee
Replied by NicBeeee on topic Re:2006 Stereo stuck CD
Quick update on the bonjovi cd, rather like an annoying splinter in the finger I have got it out. If you have got issues with your cd player and it doesn't eject and makes a clicking noise then try this.
Remove facia
Remove stereo
Remove bracket 4 large screws either side
Separate cd from radio 4 small screws either side
Hit the eject button and push back the white nylon arm (top right as you look from the front) if this ejects the cd then flip the case upside down, you will see the underneath of the nylon arm and in fact this is a gear rack, now check the clear acrylic gear cover that contains the gearing that moves the rack. If yours is anything like mine then it will be broken where it is screwed to the casing, this is allowing the gears to lift and not mesh with the rack.
If you get some araldite and weight down the casing it is easily repaired, in fact mine is now probably better than when it left the factory and only just took an hour of my time.
Sent from my F3111 using Tapatalk
  • Daniel30
13 Mar 2017 16:50 #179166 by Daniel30
Replied by Daniel30 on topic Re:2006 Stereo stuck CD
Did you test it again with the bonjovi cd?
:laugh: :laugh: :laugh: :laugh:
  • NicBeeee
13 Mar 2017 17:18 #179167 by NicBeeee
No but I have found a better use for it
Time to create page: 0.193 seconds
