really loud vibration with slight judder
- Ste372
07 Dec 2016 20:53 #175411
by Ste372
Replied by Ste372 on topic really loud vibration with slight judder
We've got same problem on ours. Jus bought it 2006 58k miles on it. Really bad vibration through the car at 1800-2500rpm only when in 4th and 5th gear.
Im changing all drivetrain fluids asap to rule them out, more for piece of mind. We've also got a leak on gearbox suspect it's something to do with the prop/seal
- kelky7777
24 Jun 2017 19:33 #182267
by kelky7777
Replied by kelky7777 on topic really loud vibration with slight judder
It's been a while but thought I'd update. After driving with the problem for several months I decided to have another go at it and asked a mechanic I know to have a look and check gearbox mount, sure enough the gearbox mount, also known as rear engine mount, was broke. The slightly annoying thing was that it was the same mechanic that checked the car the first time and even though I'd mentioned the gearbox mount and all other mounts he somehow missed it.
What I find odd is the last 2 mots for this car, before I owned it, point to failure due to 2 rotten rear shocks and a broken gearbox mount, then a pass certificate a couple of days later, when I bought it first thing I did was replace 2 rotten rear shocks and now the gearbox mount, so I reckon it was like that for 2 years and 'somehow' still passed.
Anyway, fitted a new gearbox mount and the vibration problem has reduced by around 40 per cent. but still there, in fact no change changing to fourth but third gear is now much better.
For normal driving, like anywhere outside London, where normal acceleration is possible you wouldn't notice the problem much at all and motorway performance is very smooth at around 65 mph. Despite the problems I still enjoy driving it, I never got around to finding the problem with the vacuum system but fitting manual hubs anyway.
I'm looking for some manual locking hubs if anyone has a spare set I can buy?
- Gazzt
25 Jun 2017 07:23 - 25 Jun 2017 07:24 #182270
by Gazzt
Replied by Gazzt on topic really loud vibration with slight judder
Hi Kelky
Did you find out what the transmission whine and woo woo noise was, as mine does that, 2008 plate with 51000 miles
Gaz
Gaz
Last edit: 25 Jun 2017 07:24 by Gazzt. Reason: spelling correction
- kelky7777
25 Jun 2017 21:23 #182280
by kelky7777
Hi Gaz. I think just wear and tear on mine, though I gather from looking here and there that its common with jimnys
- Gazzt
26 Jun 2017 13:47 #182290
by Gazzt
Cheers Kelky
I was wondering if the wa..wa part of the whine might have gone since you fixed the gearbox mount as it might be a clue as to where to start looking on mine.
Gaz
Gaz
- 1066Boy
26 Jun 2017 16:42 #182298
by 1066Boy
Replied by 1066Boy on topic really loud vibration with slight judder
Mine does it in 4Low but not in any other setting?
Time to create page: 0.169 seconds
