Trailmaster 50mm (2") liftkit
  • AlRayes
22 Sep 2016 18:09 #172696 by AlRayes
Trailmaster 50mm (2") liftkit was created by AlRayes
Hey guys ..
I ordered trailmasters 50mm lift kit for my 2015 Jimny, do you think I need the following parts as well:
- Extended brake lines
- Adjustable panhard arms
- rear shocks repositioners
- Castor correction bushes
Or will the lift kit be okay without them? Ill be using the car 90% on road (some areas have bad roads though)
Many thanks!
22 Sep 2016 18:33 #172697 by mlines
The kit (see here - www.bigjimny.com/store/trailmaster-50mm-...it-suzuki-jimny.html ) contains everything you need. I fitted it to my sons own car and it was fine without any other parts.
  • AlRayes
22 Sep 2016 18:49 - 22 Sep 2016 18:52 #172699 by AlRayes
Replied by AlRayes on topic Trailmaster 50mm (2") liftkit
mlines wrote: The kit (see here - www.bigjimny.com/store/trailmaster-50mm-...it-suzuki-jimny.html ) contains everything you need. I fitted it to my sons own car and it was fine without any other parts.
Mine is without the hoses and bump stops :(
Last edit: 22 Sep 2016 18:52 by AlRayes.
22 Sep 2016 19:20 #172700 by mlines
Is it an old or second hand kit, they all come with the rear hose and bump stops now?
If it is a new kit then I would complain
The following user(s) said Thank You: AlRayes
  • AlRayes
22 Sep 2016 20:49 - 22 Sep 2016 20:50 #172706 by AlRayes
mlines wrote: Is it an old or second hand kit, they all come with the rear hose and bump stops now?
Its a brand new kit, here is the link:
www.jimnybits.co.uk/shop/jimny/suspensio...ift-kit/prod_67.html
I think itll arrive on Saturday
Last edit: 22 Sep 2016 20:50 by AlRayes.
23 Sep 2016 08:19 #172711 by X8GGY
Replied by X8GGY on topic Trailmaster 50mm (2") liftkit
Trailmaster lifts are supplied drop-shipment, so you've ordered from JimnyBits and they then order from trailmaster in Germany, and trailmaster ship direct to you...
So you will get the new, latest spec' kit, with the brake lines and bump stops that Martin has mentioned...
So no worries, wait for it to arrive and they should be in the box ;)
Time to create page: 1.352 seconds
