Intermittent loss of power ?
- Thank you received: 1984
02 Sep 2016 19:44 #171946
Replied by Lambert on topic Intermittent loss of power ?
When my coil packs died they manifest as a huge flat spot in the rev band right at 2000 rpm. Replacement from eurocarparts and off we go, clean up from idle to 6500 rpm. Brilliant.
The following user(s) said Thank You: PAULWW
- skywalker65
- Premium Member
- Thank you received: 20
02 Sep 2016 21:13 - 02 Sep 2016 21:18 #171947
by skywalker65
If in doubt ...... Flat out ??
Replied by skywalker65 on topic Intermittent loss of power ?
That's correct. Initial problem was that the car started ok. Got about 5 miles in then it would occasionally hiccup. Left it a few weeks and it got to the stage where it would run ok from cold but then as heat got in to the engine it started to drop on to 2 cylinders. Fairly convinced that this ignition issue is what ultimately destroyed the cat in the manifold. Dumping unburnt fuel in to it doesn't do it a lot of good.
The feeling when the cat had collapsed was like an 2 stroke moped with a blocked exhaust. Occasionally it would clear then back to lack of power.
The coils are prone to failure due to their location. Most stick type coils seem to have a high failure rate on all types of cars.
Coils don't show up on a diagnostic as such compared to sensors. I'm assuming the iridium plugs are ok. Originally designed for the North Star engine, it's not very often that they're the cause of such issues
Last edit: 02 Sep 2016 21:18 by skywalker65.
- PAULWW
03 Sep 2016 10:35 #171966
by PAULWW
Replied by PAULWW on topic Intermittent loss of power ?
OK..revised strategy then...back to plan A..new coil packs it is. Seem to vary in price on ebay from £15 ea. to £75.
- skywalker65
- Premium Member
04 Sep 2016 07:32 #171983
by skywalker65
The original coils are Denso Paul. I got NGK ones as the weren't a bad price. Coupled with the fact they've been dealing with ignition systems for ages. Might be worth replacing the plugs if you haven't already done so. On the vvt engine they are replaced at 48,000 miles and as I have mentioned before are the iridium type.
- PAULWW
10 Oct 2016 10:11 #173313
by PAULWW
Problem solved....new coil packs and normal service is resumed !
- jim
10 Oct 2016 13:06 #173316
by jim
Thanks for letting us know how it turned out. I have the same issue.
Replied by jim on topic Intermittent loss of power ?
PAULWW wrote: Problem solved....new coil packs and normal service is resumed !
Time to create page: 0.367 seconds
