Howling/vibrations after 4" suspension lift
- MattB12
12 Jul 2016 20:25 #169944
by MattB12
Replied by MattB12 on topic Howling/vibrations after 4" suspension lift
Thank you mate, how much did that cost?
If the prop is too short and on it's limits, would that cause this noise and vibrations i'm getting?
- viciouspenguin
12 Jul 2016 20:28 #169946
by viciouspenguin
Replied by viciouspenguin on topic Howling/vibrations after 4" suspension lift
I can't remember exactly but it was a few hundred. I would just go for a basic one, the double UJ was a bit overkill
I could cause the vibration, I would poke around underneath to double check things. Check the UJs are ok too.
- OllieNZ
12 Jul 2016 20:40 #169948
by OllieNZ
Replied by OllieNZ on topic Re:Howling/vibrations after 4" suspension lift
It may also be the nose of the rear diff has been dropped to far with the caster correction. It should really be pointing at the output of the transfer case. A spacer would definitely be a good place to start.
- MattB12
12 Jul 2016 20:45 #169949
by MattB12
OK thanks a lot
I'll bear that in mind for now.
Would a spacer on the diff end help push it back in?
Just a thought, i have some 31" tyres on the way, because they are going to raise the axle a bit would that help put the prop back within it's limits? Or is that logic a bit skewed.
- MattB12
12 Jul 2016 20:47 - 12 Jul 2016 20:50 #169950
by MattB12
Edit: just seen your response OllieNZ regarding the spacer, thank you.
@ VP - Yes, I also gave the UJ a good eyeballing when the prop was off, I think the prop itself is fine.
Last edit: 12 Jul 2016 20:50 by MattB12.
- viciouspenguin
12 Jul 2016 20:56 #169951
by viciouspenguin
Bigger tyres won't change it, but a prop spacer will. Presumably the radius arms are corrected for the lift and you haven't used standard ones?
Time to create page: 0.195 seconds
