2´´ or 2.5´´ lift?
29 May 2016 09:35 #167667 by Busta
Replied by Busta on topic 2´´ or 2.5´´ lift?
It's on;y a 2011, Kirky, the standard springs and shocks should still be pretty healthy! Spacers are definitely a better option than the cheap lift kits as you are using better quality shocks and more suitable springs.
The following user(s) said Thank You: fransolis94
  • fransolis94
30 May 2016 00:46 #167699 by fransolis94
Replied by fransolis94 on topic 2´´ or 2.5´´ lift?
thank you busta! for now i will go for springs spacers and the shocks extenders! my jimny has 80000km so i think springs are good enough jaja
30 May 2016 07:16 #167704 by kirkynut
Replied by kirkynut on topic 2´´ or 2.5´´ lift?
Busta wrote: It's on;y a 2011, Kirky, the standard springs and shocks should still be pretty healthy! Spacers are definitely a better option than the cheap lift kits as you are using better quality shocks and more suitable springs.
Yes, if the mileage isn't too high. It's use rather than age. I'd put the Trailmaster kit above standard Suzuki in terms of quality though!
  • TomDK
30 May 2016 10:50 #167709 by TomDK
Replied by TomDK on topic 2´´ or 2.5´´ lift?
There are also shocks from Bilstein and Koni. Both comes in standard length. But probably the best option of shocks available for the Jimny :)
  • fransolis94
30 May 2016 14:37 #167715 by fransolis94
good information! could the brake lines be affected or even damage with the 2 or 2,5 lift? :unsure: i dont know if the articulation could damage them :dry:
  • 1066Boy
30 May 2016 16:27 - 30 May 2016 19:01 #167717 by 1066Boy
Replied by 1066Boy on topic 2´´ or 2.5´´ lift?
Brake lines are fine on a 2" lift if the ARB is left on. Taking it off gives you more articulation
but you will have to get longer ones. :)
Last edit: 30 May 2016 19:01 by 1066Boy.
Time to create page: 0.187 seconds
