285-75-16 tyres and axles
- Generallee
10 Apr 2016 19:18 #165160
by Generallee
285-75-16 tyres and axles was created by Generallee
I have a Range Rover diesel with above tyres front and rear winches Etc but I've acquired a jimny I want to develop into a challenge truck
Are 33-34" insa turbos going to blow front cvs every time I go out?
Not worried about lift or cutting info etc I'll make them fit, or ratios I'll make a rock lobster box and even fit Landy or Toyota axles in long run but be nice to be able to use it a bit before destroying standard axless so.... Will axles handle them if I'm careful? Or is it just too much tyre?
Thanks ken
Thanks ken
- Generallee
10 Apr 2016 20:08 #165170
by Generallee
Replied by Generallee on topic 285-75-16 tyres and axles
That's exactly what I to hear thanks
11 Apr 2016 14:08 #165191
by kirkynut
Replied by kirkynut on topic 285-75-16 tyres and axles
You will blow CV joints.
- TomDK
11 Apr 2016 15:22 - 11 Apr 2016 15:23 #165195
by TomDK
Replied by TomDK on topic 285-75-16 tyres and axles
Agree with Kirky. And if not CVs then shafts.
But why such big tyres on a tiny car like the Jimny?
Last edit: 11 Apr 2016 15:23 by TomDK.
- Generallee
11 Apr 2016 15:45 - 11 Apr 2016 15:47 #165197
by Generallee
Because I can? Have them?
I have them on Range Rover and diffs ground out now at play sites so I don't really want to go smaller as I still want to be able to go through the stuff I've done in rangie
Thanks
Thanks
Last edit: 11 Apr 2016 15:47 by Generallee. Reason: Spelling
- Venter
11 Apr 2016 16:16 - 11 Apr 2016 16:18 #165198
by Venter
Replied by Venter on topic 285-75-16 tyres and axles
You will find that with the narrower track of the Jimny that you don't use the same wheel ruts as other vehicles at the play sites, you'll usually have one in the rut and on on the edge of the raised central bit. This is one of the Jimny's strengths, as it can get past the rutted areas that are catching everyone else out.
There are far more usuful upgrades for the Jimny than this to spend your time and/or money on.
Last edit: 11 Apr 2016 16:18 by Venter.
Time to create page: 3.412 seconds
