Spring Height vs. Lift
- Thank you received: 226
I have seen numerous comments about springs that are rated for a certain lift but, in reality, don’t provide the lift that they claim. What I would like to understand is whether that is due to the manufacturers simply categorizing them or if it’s due to them being installed on vehicles that are already heavier than stock. After I installed my front and rear bumpers, along with a roof rack, my Jimny now sits 20+ mm lower. Not exactly a surprise. Neither would I be surprised if I purchased springs designed to lift a Jimny at curb weight by 40mm and they only lifted my heavier Jimny 30mm. I wouldn’t be concerned except I am not likely buying a lift kit but rather longer springs and shocks separately. When I do, I would like to make sensible decisions.
Any help and comments are appreciated.
Bob
- Thank you received: 1875
Unfortunately because the car is a jimny not a land rover my knowledge of availability of off the shelf springs to solve your problem is non existent, sorry. That said others may well know especially Tom DK.
My assumption has been that the Jimny specific springs designed for a 2 inch lift have been designed with a spring rate and height that would accommodate the base weight of the Jimny (or equivalent) providing the advertised lift.
Touching on one point you made, I am not a fan of a lot of lift. I may be a minority but I think it is practical to keep it as close to stock as possible, taking into account other mods. I am looking to recover what I have lost along with a little additional.
Thanks again.
- TomDK
zukebob wrote: I know the subject of suspension has been beaten to death but I haven’t found an answer to this question. Not on this forum or elsewhere.
Bob
In short. You need to buy springs that match the sprung weight of your vehicle. This is why I always recommend getting springs from either trail master or OME as all their springs are with known spring rates. Rather that than buying cheap springs of unknown origin and rates.
If your Jimny is that heavy perhaps you should take a look at the diesel springs from trail master
11/60: progressive rate springs, specifically dual rate, is one of the things I was pursuing. Tough Dog apparently makes dual rate. OME, King and Dobinsons all make progressive rate springs but none list any specifically for the Jimny. I’m guessing none of them have any, producing only the linear rate. Perhaps when I finally get a reply (if I do), I will finally know.
Tom: OME was my first plan but then I thought maybe a quality set of Jimny springs with either Bilstein or Amada Extreme shocks. Started to move away from OME hearing that they tended to be somewhat soft. King springs apparently have the same reputation. I think now it’s time to probably go back to OME and start my own hands-on experience.
Thanks to both for the feedback.
