Belt whistling
  • emu88
15 Mar 2016 10:13 #163780 by emu88
Belt whistling was created by emu88
One of my belts whistles occasionally when I accelerate - is this an urgent job or can I drive around like this for a long while?
  • Decklandpt
15 Mar 2016 14:25 #163786 by Decklandpt
Replied by Decklandpt on topic Belt whistling
wich belt?
mine's been doing that for a couple of months now, narrowed it down to the alternator bearing, gonna take it to the mechanic today. mine's having no trouble with it. when it squeals i just step on the loud pedal, once it hits 4000rpm it stops and doesnt do it again till the next time i start the engine after a while parked
  • emu88
15 Mar 2016 14:34 #163787 by emu88
Replied by emu88 on topic Belt whistling
Decklandpt wrote: wich belt?
Not sure which belt, but one of them looks worn, the other looks like it has plenty of life left in it. If it's the alternator bearing is that a quick job? I think my alternator is fine, so was planning on just swapping BOTH the belts.
  • Decklandpt
16 Mar 2016 11:52 #163825 by Decklandpt
should be, i hope, i'll get back to you by the end of the week when i get the car back
16 Mar 2016 12:35 #163826 by maverick
Replied by maverick on topic Belt whistling
The thing is - its a LOT easier to take the radiator off to change Fan (Alternator) Belt and P/S Belt has to come off first ...
So while Radiator off, best to change both - as a pair they are only £20-ish
Jalapeño, IISY?
16 Mar 2016 13:47 #163832 by facade
Replied by facade on topic Belt whistling
maverick wrote: The thing is - its a LOT easier to take the radiator off to change Fan (Alternator) Belt and P/S Belt has to come off first ...
It is easier, but takes a lot longer, and you have to drain the water.
The fan belt will feed in through the fan blades as you rotate the fan by hand.
Time to create page: 1.387 seconds
