New Jimny owner - gearbox oil leak/propshaft issue
  • VVTJim09
31 Oct 2015 16:54 #154964 by VVTJim09
A lot of the oil was cleaned off by the garage when the seal was replaced. I'm getting a lot of vibration/reverberation at low rpm now. It's going into the garage on Tuesday and then I'll see if I can get hold of a used prop once they have confirmed it for me.
31 Oct 2015 17:09 #154966 by Basketcase
I had that problem on my old Jimny but I just cleaned the prop but that goes into the gearbox output shaft with brake and clutch cleaner then put silicone sealer all over the end of it inside the prop and on the uj as well and that stopped the leak. Much cheaper than buying a new prop
  • VVTJim09
02 Nov 2015 11:33 #155147 by VVTJim09
Are the props the same across the years or will I need one from a similar aged Jimny?
Thanks
02 Nov 2015 12:30 - 02 Nov 2015 12:34 #155156 by gilburton
You need one from a VVT 2005/2006 on.
The gearbox is different and the prop is a different length.
The oil seal is standard across all gearboxes.
The gearbox on the VVT Jimny is the third type they have fitted.
I started off high and worked my way down ever since :-)
Last edit: 02 Nov 2015 12:34 by gilburton.
The following user(s) said Thank You: VVTJim09
Time to create page: 0.674 seconds
