Bad Fuel Consumption
  • Venter
08 Oct 2015 09:42 #153202 by Venter
Replied by Venter on topic Bad Fuel Consumption
It seems like my brakes are binding. How do I go about sorting this out?
  • Al.
08 Oct 2015 10:13 #153205 by Al.
Replied by Al. on topic Bad Fuel Consumption
I average 32 around town,
39 on a trip,
29 to 30 towing.
best so far 331 miles for 37lts on a single none stop trip @ 56 to 60 mph
08 Oct 2015 10:25 #153206 by mlines
Replied by mlines on topic Bad Fuel Consumption
If it is your brakes binding then they will be red hot after a trip.
You can then buy refurbish items such as:
New sliders and rubber boots (these are a key source of binding issues)
www.bigjimny.com/store/caliper-fitting-k...in-suzuki-jimny.html
New pistons
www.bigjimny.com/store/caliper-piston-aisin-suzuki-jimny.html
However if you are starting to look at corroded pistons then a new caliper can be cheaper than the effort of refurbishing your own
www.bigjimny.com/store/front-brake-caliper.html
08 Oct 2015 15:33 #153222 by Rhinoman
Replied by Rhinoman on topic Bad Fuel Consumption
A compression test will give you an idea of how sound the engine is. If you haven't had a new lambda sensor for a few years then its worth replacing that, a bad sensor will affect the fuel consumption long before it throws a code.
  • Venter
08 Oct 2015 22:35 #153270 by Venter
mlines wrote: If it is your brakes binding then they will be red hot after a trip.
New pistons
Thanks for the info Martin.
I was a bit worried after my first drive following my kingpin bearing rebuild, as I thought maybe I'd misaligned the caliper or disc when putting things back together. The wheel wasn't turning freely by hand, and on the road there was major burning brake pad smell. This settled down by the end of the drive, so I'm hoping it was just things getting bedded in etc.
Luke
  • hora
09 Oct 2015 12:49 #153294 by hora
Replied by hora on topic Bad Fuel Consumption
Wow. I get 300miles to circa 36litres (answers on a postcard why it wont fill over this). It hasn't run out yet but I stop/refill before it gets 20miles+ after the fuel light comes on.
I'm not shy with the revs either. I'm a firm believer that once warmed up a petrol engine should use all (excluding redline) of its rev range daily.
Time to create page: 0.154 seconds
