Cleaning rear lenses
- suzukisam
Failing all that get rid of the bumper lights and convert the body lights to do the job I did
emu88 wrote: On a slightly unrelated topic, I assume the mounting point of the damper for the boot door ought not be at an angle, but vertical? Mine is bent so I assume the door has been yanked hard before.
should be able to twist it back straight
for more details see here
emu88 wrote:
Daniel30 wrote: Yeah the number plate lenses just get stiff with dust and grit, if the mount is leaning towards the front of the car then it would have been shut to hard can't quite see from the photo
Thanks! Thats just a generic pic, mine is bent about 30deg away from the car.
Any ips on getting water out of sealed lenses?
How about drilling a little drain hole it's not as if they are sealed anymore
- emu88
Great! Thanks. The threads on the chassis are actually bent, so I'll have to see if I can get a screwdriver in the opening under it to whack it back straight.
Done, worked well. I'll re-seal the tiny hole and then reseal the lenses themselves.Daniel30 wrote:
- emu88
What if i silicone round the joins though of the lens itself?Daniel30 wrote: Well done
might aswell leave the hole otherwise it will fill up again
