Cleaning rear lenses
- emu88
27 Sep 2015 09:31 #152605
by emu88
Cleaning rear lenses was created by emu88
The lower rear lenses (horizontal ones) have water in them. Although there are clips on the back, it's on really tight so i wonder if they are not meant to be removed. Is it possible to remove the lenses, clean then put back?
27 Sep 2015 09:43 #152606
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Cleaning rear lenses
No the are glued together
Grey pick up Jimny
- emu88
27 Sep 2015 10:10 #152607
by emu88
Replied by emu88 on topic Cleaning rear lenses
Ok thanks. I'll see if I can get the water out another way. What about the number plate lights? They appear to have two little area to turn and unscrew but for the life of me I cannot open them by hand:
On a slightly unrelated topic, I assume the mounting point of the damper for the boot door ought not be at an angle, but vertical? Mine is bent so I assume the door has been yanked hard before.
27 Sep 2015 11:09 #152609
by j999pre
Grey pick up Jimny
Yes number plate lens comes off as described
Grey pick up Jimny
27 Sep 2015 13:24 #152612
Replied by Daniel30 on topic Cleaning rear lenses
Yeah the number plate lenses just get stiff with dust and grit, if the mount is leaning towards the front of the car then it would have been shut to hard can't quite see from the photo
- emu88
27 Sep 2015 17:27 #152621
by emu88
Thanks! Thats just a generic pic, mine is bent about 30deg away from the car.
Any ips on getting water out of sealed lenses?
Daniel30 wrote: Yeah the number plate lenses just get stiff with dust and grit, if the mount is leaning towards the front of the car then it would have been shut to hard can't quite see from the photo
Time to create page: 0.506 seconds
